FixYa.com
Tags:
Air Conditioners
Generic problem for all Air Conditioners
Intertherm outside unit - s3ba-036k - does not run
posted by wiljd52 on May 17, 2008
unit was working and quit.unit has power and control voltage.neither fan or compressor run.contactor pulls in when thermostat calls for a/c.contactor has 125vac on both sides.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 17, 2008
Not Rated (0)
22yooper
Rank:Guru Guru
Rating: 85%, 346 votes
Measure the voltage across the line. The outside unit normally runs on 220 Volts. Measuring each side of the line to ground will give 110 Volts. If your outside disconnect is of a fused type one fuse could be blown. If a fuse is blown on one side of the line you will read zero volts differential across the line.
Check the type of fuse used in the disconnect. Make sure the proper size time delay fuse is installed on both sides of the line at the disconnect.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE Profile ASM10AA Air Conditioner Panasonic CW-1006FU Air Conditioner Panasonic CW-C60RU Air Conditioner DeLonghi PAC220SRB Portable Air Conditioner Goodman CKL49AR49 Air Conditioner Goodman CKL60AR60 Air Conditioner Haier HPRD12XC5 Air Conditioner
Can you Help with these Air Conditioners problems?
Air Conditioners
My split system airconditioner...
My split system airconditioner... Answer This...
Air Conditioners
I have a split system
I have a split system... Answer This...
Air Conditioners
a/c
my central unit blows for 8... Answer This...
Air Conditioners
I have a Trane heat
I have a Trane heat pump with a... Answer This...
Air Conditioners
fan not working
fan not working Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
