Need a square tool to remove Whirlpool S70 agitator's plastic centerpiece and I don't have the correct ratchet adapter size!
    Problem Solver:
  • 15 Answers
Buy a cheap basin wrench in the plumbing dept at the hardware store.
cut off the ones that are too small with a hacksaw
Posted on Sep 16, 2010
The agitator on my Whirlpool (8280869) is rubbing/grinding. It seems the ratchet system is not catching on the center post when the agitator starts to spin. Can this be fixed?
On whirlpool/kenmore direct drive machines, the part you are referring to is the 'agitator dogs.' They are paisley shaped plastic pieces with teeth on the outer edge... Usually a 7/16 nut or a square plastic drive(1 inch socket adapter fits it perfectly) holds down the top half of the agitator. The pivot end of the 'dogs' must be inserted into their slot and should all face the same direction...
Apr 27, 2016 | Whirlpool Washing Machines
Need to remove the tub on Kenmore Series 60 Washer to clean it. How do I get the agitator out?
To replace the Agitator & Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa!!
Aug 04, 2011 | Washing Machines
I'm preparing to replace the agitator dogs on my Whirlpool/Kirkland SAWS800JQ2. Is the plastic gasket exposed after removal of the softener dispenser merely in need of a good tug to expose the nut for...
Nov 14, 2010 | Whirlpool Washing Machines
I have whirlpool model LSR7233EQO and one belt of cotton stuck under the propeller
If you are referring to something being caught under the agitator, you can remove the agitator easily, by following these steps:
1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up.
With the agitator removed, you can easily retrieve anything caught underneath. When reinstalling the agitator DO NOT overtigthen the center post nut. Tighten until snug.
If this is not what you are referring to, please post back and let me know, so I can provide you with better assistance. I hope this is helpful to you.
Feb 28, 2010 | Washing Machines
How do i disassemble the top part of the agitator on a washing machine? it seems the top part of the agitator is not spinning like it should.ile
Whirlpool washers are equipped with a split type agitator. The top is called the "auger", the bottom is the agitator. To disassemble, follow these steps:
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
If you have further questions, or need additional assistance please let me know. I hope this helps you.
Nov 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How do you take apart an agitator on a Whirlpool Estate Washing Machine
The agitators on Whirlpool manufactured washers usually have a split design. The upper portion is known as the "auger", the lower portion is the agitator. To get the whole assembly apart just follow these steps:
1. Remove the auger center cap/dispenser by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
4. Remove the auger by carefully pulling straight up. Try to keep all the cam assembly parts assembled while doing this, so do not pull too hard. This will make this reassembly much easier.
5. With the auger removed grab the agitator at the bottom flanges and pull straight up to remove from the gearcase shaft.
If you need an illustration of how the components go back together, refer to any of these websites for helpful exploded view diagrams:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
NOTE: When reassembling, make sure you get the auger seal seated properly. If it is not sealed, water will leak into the gearcase shaft and ruin it.
If you have any questions, or need further assistance, please let me know. I hope this helps you.
Oct 06, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
How can one remove the agitator,it seems to move slower than it used to
If this a Whirpool manufactured washer (this includes Kenmore, Estate and Roper), the agitator can be removed by following these steps:
1, Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap. Some washers will have a fabric softener dispenser on the center post.
If you have questions, or need additional assistance, please let me know.
NOTE: When reinstalling the agitator make sure you do not over-tigthen the bolt. This can damage the agitator and restrict its movement. Tighten until snug.
Jul 08, 2009 | Whirlpool WTW5500ST Top-Load Washer
Need help replacing the Agitator/Mover
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 30, 2009 | Washing Machines
Grease is leaking out from under the agitator, getting on clothes
Apr 09, 2009 | Kenmore Washing Machines
Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Dec 31, 2008 | Kenmore Washing Machines
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
