Panasonic CT-27SL15 27" TV Logo
Posted on May 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic CT-27G14A Panasonic CT-27G14 A has raster but no picture and no sound and when u install a dvd player in the video input u get snowy picture with no sound
Ekse
Level 3:
  • Panasonic Master 13,435 Answers
  • Posted on May 17, 2008
Ekse
Panasonic Master
Level 3:
Answers
13435
Questions
82
Helped
3985126
Points
38023
Have you tryed both the front and the back inputs?
  • Ekse May 17, 2008
    You accecpted the solution? Is the problem solved now?
Universal remote code for a panasonic ct-27g14a
Two things you can do:
GOOGLE THE NUMBER OR MODEL OF THE REMOTE AND LOOK FOR THE INSTRUCTIONS FOR PROGRAMMING IT.
GOOGLE THE MODEL NUMBER ON THE REAR OF THE TV WITH THE WORD REMOTE AFTER IT FOR A DIRECT REPLACEMENT.
LET ME KNOW IF YOU NEED HELP
I bought a panasonic model ct-27g14a tv from a thrift store when i got it home i found that the parental lock was activated and did'nt have the code.
Sorry,u must have it orignal codes,there noway to unlock secrect personal codes.U push the channels + or - buttons manual controls couples times.Might get in the tv input.Hook up,use it with DVD player can watch DVD Disc thought.Sorry, you probally only can watch shows rated Y for children only.
6helpful
Remote sensor on Panasonic CT-27G14 not functioning. How can I fix it?
firt try with your cellular, put your cellular in camera and put your remote control in front of your cellular and press one botton, if you see a blincking ligth, your control is good and your IR sensor in the tv is bad.
1helpful
No picture, No sound only snowflakes!!! Can you help?
Make sure that your tv is on the av setting(or hdmi what ever the input is) also make sure the input is working by testing it with another device (dvd player,etc) If you are getting snowy picture you could be on the analogue tv channel. Good luck.
PANASONIC CT-27D30B
Maybe the vertical IC output are damaged you need to replace him
Panasonic COLOR CT-27G14A
check Vertical IC out (LA78..) and resistor voltage supply from flyback transformer to this ic. Check the STR main power supply(and resistor near, change value), some times seems good out main board,but in operation not good
MDVD-6838 and Panasonic Plasma TV incompatibilty
1 click SETUP(left just below the four arrow w/ enter button in the middle)
2 click DISPLAY
set tv system to AUTO
tv image to 16:9 WIDESCREEN
video setup (depend on the connection)
s video or RGB
1helpful
Panasonic CT-36SL13 Can't select video inputs
On a Panasonic to do a factory reset while the set is on press in on the power and action buttons on the front of the TV at the same time. In a few seconds the screen shouls go blank and come up with a screen that says "CHK" in the upper left hand corner. Once it does that press the action button again to clear the screen. You have now reset the TV to factory settings and will have to re-program the channel memory once again. Hope that works...
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
