Question about Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
My cme 256a8 model scotsman ice melts to fast will not fill my 250 lb. bin in four days. What is the problem? in a hour run time it makes 7 lbs of ice and 4 lbs. water. in one dump cycle it makes 3 lbs 40z of ice but it melts really fast. building temp. is 74 degrees f
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 107 Answers
Check bin drain make sure bin isnt holding water in the bottom of it
Posted on Apr 20, 2012
  • 4 Answers
CME256.A
your comment of ice melts to fast is directly related to the ice collected in the bin. 1. check ice formation. is unit level? 2. measure water temp/air temp.
Example caluculate 24 hr prodution
1.measure time of one complete cycle
sample:
Divide 24 hr/cycle time (1440 min)
time= 15min collected ice weight=5.5 lbs
1440/15 x5.5=96 96x5.5=528lbs per 24/hr.
Also check your water valve should be off during ice making mode. SMALL AMOUNT of water can cause no ice or low production levels at harvest.
room temp and bin condition at the bin boor can contribute to melting ice.
Posted on Nov 29, 2010
    Sergeant:
    Novelist:
  • 193 Answers
There are a couple of things to check. The machine must be level. You can remove the front cover and the plastic sheet that covers the plate where the ice is made. Check to see that the water is flowing from the manifold at the top of the plate. You may have to pop the hose off the end of that manifold to clean the water holes out. It must flow evenly over the plate. Probably the most common problem is the radiator coil there the fan draws air through is clogged up so that it can't dissapate heat properly. You should be able to feel a lot of hot air moving through the coils. The fan cycles on and off periodically to maintain a certain pressure in the freon. That is normal. Clean the fan coils and level the machine.
Posted on Sep 16, 2010
  • nextdoor228 Sep 23, 2010
    the water flows evenly over the plate.
    The bin and ice machine is level.
    the problem is the ice seems to not be freezing hard enough too maintain volume. it melts too fast to fill my 250 lb.bin
    thanks for you suggestions though
I have a CME656AS-32F, IT WON'T HARVEST
if your cme 656 wont harvest, most common prooblem is your sump level control or wire harness. check to make sure your water valve isnt leaking thhrough
Apr 19, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
Won't make ice
The bin should fill up and the machine shut off in 24-36 hours from time it is turned on. If not the condenser coil may be dirty.
1.Clean the coil this should be done every year.
The bin brain may be partially restricted causing ice to melt faster.
1. clean out the drain.
The air flow to the condenser may be obstructed.
check to make sure there is nothing covering up the grill or coil.
Nov 29, 2013 | Scotsman DCE33PA1BC 15in Built-in...
DC33 PA 1A
If the machines ice storage capacity is 26 lb per a day then that is all it will make in a 24 hr day Now this depends on water temp entering the machine, the ambient temperature around the machine and the condenser coil and fan is not dirty. Now the machine is capable of making 33 lb of ice in a 24 hour day but the storage bin capacity is only 26 lb if you don't remove any ice it will make only around 26 lb and shut off until it melts and causes the ice maker head to start.
Nov 26, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman cme 1656 bill full stay on after cleaning
Ok did you damage the bin thermostat cap tube? The bin thermostat is what tells the unit the bin is full if so replace it.
Nov 14, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman icemaker dce33 is making ice, but it is melting
Yes it could and also check dump valve it should not let water through during freeze cycle.
Oct 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
DCE33 Ice Machine
I believe it was the inlet water valve that needed to be replaced, but I got so fed up with the noise and repairs on this machine that I purchased a Whirlpool ice maker. So far, it's been great. It is much more quiet and produces 50 lbs of ice in 12 hours and shuts off until some of it melts. It only produces more ice about four times a day as it melts.
Sep 27, 2008 | Refrigerators
Kitchen Appliances - Others Logo
538 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
