Question about Xante CL30 HSE Laser Printer
What does error code 032 fatal error mean and how can I fix it
  • 734 Answers
Here's the link to your 500 page Manual. I used the search function at the top of the Abobe Doc which it is formatted as and typed in your error.
It won't call up anything about 032 but Fatal Error recommends only "Call For Service".
Not very helpful is it?
Oh well, please don't thrash my rating with 2 blue thumbs or less. I tried. :(
Regards,
MArcus
Posted on Sep 16, 2010
  • LeoMB
    LeoMB Mar 06, 2014
    Where is the Link?
How can solve xerox 4110 error code 093-311
This code means toner mot fail so check for toner caking after that go mvm location 762-032(write down current val just in case) whatever value ...A Hard reboot might be needed shut it down an turn up after 5 minutes
Oct 04, 2017 | Xerox Office Equipment & Supplies
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
May 25, 2011 | OKI C5200n Laser Printer
Fatal error 708
Dec 14, 2010 | OKI C3530N Color MFP Printer
925 fatal error
www.okidata.com/canada_en/downloads/C9600_Bertl_4Stars.pdf
all in manual above. http://www.okic3200n.co.uk/index.asp?printername=C3200n&menumode=0&content=errorcodes
error codes above.
May 08, 2010 | OKI C9600hdn Laser Printer
Brother hl-5270dn is desplaying the error code S01? What does this mean?
S01 = Fatal error EX
1) turn off the printer
2) wait a few seconds
3) turn it on again
H63 = DRAM access error
3) turn it on again
Sep 11, 2009 | Brother HL 5250DN Laser Printer
Konica Minolta magicolor 2430DLshowing Fatal o8h
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely.
Apr 18, 2009 | Konica Minolta magicolor 2430 DL Laser...
Minolta Magicolor Fatal Error
Remove each of your cartridges one at a time and see if you can spin the toner rollers by pushing on the little white plastic gears with your finger. They will be tight but you should be able to spin the roller by moving the little gears around.
My printer started giving the Fatal Error Code 17H and I did all the removal of the four color cartridges and re-seating each of them to no avail. After removing each cartridge and checking to see if I could rotate the toner roller I found that the yellow cartridge was extremely tight. I took the cartridge outside and used a can of compressed air to blow all the toner off the roller and tapped the cartridge on all corners and shook it back and forth several time. Finally I was able to get the toner roller so that it would rotate when pushing the little white gears like the other three cartridges.
After replacing the cartridge in the printer it worked with no more error codes. Hopefully this will fix the problem until I can order a new yellow cartridge.
Keith
Jan 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Xante CL30 HSE Laser Printer Logo
274 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
