Question about GE Microwave Ovens
Microwave only runs for 22 seconds - GE Microwave Ovens
  • 1 more comment
  • paknbu May 17, 2008
    timer OK - oven runs for 22 seconds
    microwave only runs for 22 seconds, have checked all the settings, it just shuts itself off
    I just punch the usual time buttons and start button. If I set the time for 2 minutes, it runs 22 seconds. If I set the time for 30 seconds, it runs 22 seconds
  • GE Master
  • 13,433 Answers
Its most likely a protective system, I beleave you microwave is in need of service.
Posted on May 17, 2008
    Brigadier General:
  • 3,614 Answers
Have you check, if the oven timer was set ON..
Thanks
  • 1 more comment
  • micromaster
    micromaster May 17, 2008
    please specify the maker / model of the oven that you have there..
    thank you.
  • micromaster
    --& you set the timer of the oven on what settings.. please provide some additional info. which you think can help us analyze this thing..
    thanks.. & post back again here..
  • micromaster
    it always stops on 22 seconds... even you set into a different time settings...
    please provide us a clear information on this prblem.. & don't rate us if the problem has not yet solve..
    -or- you can rate us if your not satisfied nor convinced on our initial provided solution, for you to find another solution from the expert..
    Genius:
  • 1,665 Answers
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos May 17, 2008
    I have intermittent cooking problems
    This link may help u
    Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
    A solution given by somebody and had result.
    "behind the control panel mounted on the bottom plate is a temp sensor that read 120. I jumped that sensor and the problem resolved. I replaced the sensor and have had no problem since"
Microwave stops mid cycle
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Dec 27, 2012 | Panasonic NN-T664SF Microwave Oven
Microwave shuts off after 22 seconds
Any product that uses electronic parts is subject to failures. That's why warranties exist. Contact Bosch on their webpage to get assistance.
Nov 16, 2017 | Bosch 500 HMB5050 Microwave Oven
Microwave starts as normanl but cuts out after 5 seconds on all settings?
sounds as either inverter or magnetron is faulty difficult to diagnose although when mag fault usually runs for about 22 secs inverter fails sooner around 5 secs.
Apr 09, 2010 | Neff H5642 Convection / Microwave Oven
Microwave stops after 22 seconds
Not sure what the problem is but I have exactly the same fault with mine. Apparently it's either going to be the inverter, the magatron or both. Cost approx £120 inc callout.
My advice: Get a new one!
Feb 19, 2010 | Panasonic Microwave Ovens
The oven stops partway into the set time, and doesn't heat.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other. Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these. You can find an authorized Panasonic servicer here. In Canada, you can find an authorized Panasonic servicer here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 11, 2009 | Panasonic Microwave Ovens
Bosch HMT8655GB, after being used no heat and cuts out at 22 secs
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
e6tuwe
May 12, 2009 | Bosch HMT8655GB Microwave Oven
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
Runs for 30 seconds then goes off. No heating
Is it 30 seconds or 22 seconds?
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 04, 2008 | Panasonic NN-S254BF Microwave Oven
Panasonic microwave oven NN-S960BC/WC begins to operate then stops after about 30 seconds, no warmth, control panel stays on but program ends.
Is it by chance running only 22 seconds before it shuts down?
The 22 seconds is the giveaway. In most cases, this is a problem with the inverter or a bad magnetron.
Jun 19, 2008 | Panasonic Microwave Ovens
Shuts Off after 22 seconds
Time to buy a new microwave as it sounds as if the control panel is defective. A new control panel for this micro will run about 95 to 120 bucks + labor depending on where you buy it. I happen to like slightly burnt popcorn as well!! Nothing wrong with thats, as they say great minds think alike.
Aug 25, 2006 | Panasonic NN-S933BF Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
