Question about Fuji FinePix A120 Digital Camera
Always shows not initiated on LCD - Fuji FinePix A120 Digital Camera
  • 3,083 Answers
Either the camera is having a battery problem, or a lens issue:
Here are a couple sites that explain what you can do to try to correct this:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
and:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Even though the article is entitled "lens error", it also applies to stuck lens issues.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 16, 2010
How to reset the bizhub 20 printer fuser counter ?
Press the [Menu], [Start] ,and [up arrow ] button four times quickly in this order to make the machine enter the maintenance mode.
The machine beeps for approx. one second and displays " " on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the buttons.
Press the [8] and [8] keys in this order in the initial stage of the maintenance mode.
(2) The LCD shows the "Reset Laser Unit".
(3) Press the [ ] or [ ] button to select the item you want to reset. The LCD shows.
"Reset-Laser Unit"
"Reset PF-KIT T2"
"Reset PF-KIT T1"
"Reset PF-KIT MP"
"Reset-Fuser Unit"
(4) Press the [OK] or [Start] button, then " *** OK?" will appear on the LCD.
(5) OK: Press the [Start] button to reset the counter of the selected part and returns the
operating procedure (2) mode.
NG: Press the [ ] button to return the operating procedure (2) mode. Then select again
the part which you want to reset by using [ ] button or [ ] button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 21, 2018 | Konica Minolta bizhub Office Equipment &...
UNABLE TO INIT 4F BROTHER DCP-195c CAN'T TO PRINT.LCD SHOW UNABLE TO INIT unable 4F. my brother printer when on the screen show unable to print. how to solve the problem ?
The printer have its own initialization but seem to fail to complete initialization process. Check and clear the carriage jam, open check for motor failure in the carriage system.
Dec 18, 2015 | Brother DCP-195C Inkjet Multifunction...
Delayed sound on lg LCD TV
My guess is that a chip or chips are beginning to fail. These chips can sometimes be replaced but be sure to get a written quote because sometimes it is more expensive to fix then it is worth. It is also not always a perfect fix. Unless chips are replaced with identical chips sound can be out of sync, tv features can be lost or any other possibilities.
Nov 10, 2013 | LG Televison & Video
Tuning channels on 32LG7 plasma TV
Searching for active channels usually is part of initial setup. You can always return to the setup procedure and repeat the search
Sep 29, 2013 | LG 32LG710H 32" LCD TV
LCD screen displays always "LOADING" when connected to PC USB
This is a Battery Issue as the Player is only Turning On when its Connected to the Computer!
Dec 29, 2011 | Audio Players & Recorders
Not working always show "turn thepower off and on
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
·Turn off the camera.
·Remove the battery pack.
·Press and hold the power button for 30 seconds.
·Allow the camera to remain without power for 60 seconds.
·Reinsert the battery pack.
·Turn on the camera.
Also try initializing the Camera if you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
If the issue persists again, service is required. Pleaseclick hearto locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Aug 01, 2011 | Sony Cybershot DSCW310 Digital Camera
ALWAYS SHOW " 1024 X 768" HERZT. CAN'T SHOW
Hi, Same problem as mine! Are u suing the original Samsung CX511n cable? If not, video will not appear! Buy the original cable!
Jun 15, 2011 | Samsung SyncMaster 510N/512N,SyncMaster...
Transfer belt warning on oki c3200. How do I reset
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | Office Equipment & Supplies
Samsung Samtron 94V N Screen setting problem
Perhaps other than the screen resolution you need to also lower down the refresh rate (found in the advanced tab of the display properties).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 19, 2008 | Samsung 94V 19 inch LCD Monitor
Fuji FinePix A120 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
