Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Belkin I cannot get a wireless connection with my Belkin wireless G plus Mimo F5D9230-4 router on my advent laptop (Windows XP) using the CD its saying connection failed, Is there a way to do it manually? Driving me crazy!
  • Anonymous Oct 06, 2008
    my internet works gr8 but the wireless doesnt work , i dont know why
    my wireless doesnt work on my belkin router
    Problem Solver:
  • 6 Answers
Yes there is just follow the following:
To setup your Belkin Router please follow the steps below.
Once the router is connected, check if your PC is communicating with the router. On the desktop click on Start and then on Run. In the open box, type cmd.
It will bring up the command prompt window.
Type the command ipconfig in that window and press the Enter / Return key on the keyboard. It will bring up results similar to the image below
Note the values of IP Address and Default Gateway in the ipconfig command results. If the IP address is in the range of 169. 254.x.x or 0.0.0.0, then the PC is not communicating with the router. In this case contact your router vendor for support.
If the IP Address is in the range of 192.168.x.x then the network setup should be ok. Note the values of IP Address and Default Gateway. Close the command prompt window. The default gate way for belkin is 192.168.2.1
Open Internet Explorer window and in the address bar type in the address that you found for Default Gateway. In case of Belkin router it should be 192.168.2.1. Then click on the Go button.
It should bring up a screen similar to the image below. Refer the product manual for the default Router password. In case of most Belkin routers, it is blank. So, just click on the Login button.
This should bring up the Belkin Router Setup Utility. Click on the Wizard link on the top bar of this page. In the Connection type options, select PPPoA. Then click on Next button to continue. Notice that on the top right side of the page, it says "No Connection". Once the setup wizard is complete, it should change to "Connected"
In the next window that appears, enter the broadband email address and password in the respective boxes. Then confirm the password in the Retype Password box. In case of VPI/VCI:, type 0 and 38 in the left and the right boxes respectively. Then click on Next to continue.
Click on the Apply button to save the settbelkin - belkin009.jpgr />belkin009.jpg
It may take up to 5 minutes to save and update the settings. Once completed, you will see, "Connected" on the top right side of the window. Once you see that close this window and open your browser window to go to any website.
Posted on May 17, 2008
Can a belkin network card f5d7050 work with a belkin g plus mimo router
As MIMO is compatible with all wireless g products there shouldn't be any issues at all....
so some questions:
  • do you have other wireless devices working with the router? if so can you duplicate their settings for this n/w card?
  • have you set security on the router?
  • what are you using to connect to the network the windows interface (assuming it's PC not MAC based) or the Belkin one?
i have a linksys g n/w card attached to my MIMO router & it's fine so I'm sure that this is solvable!
Sep 06, 2010 | Belkin F5D9050 Wireless G Plus MIMO USB...
Have wireless G plus MIMO router and lapto using a
Please enter to the router page and decrese the chanel. make it to 6 or 11
May 01, 2010 | Belkin (F5D6230-3) Wireless Router
I just reset a belkin g mimo router I cant conect
connect your laptop to your router via patch cord to be able to access the router configuration, then configure it, change the wep keys..etc
hope this thing help
Jan 10, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cannot connect to internet with ps3 using belkin g plus mimo..
you might need to disconnect your modem for 30 secs then reconnect it . i have just reset my router and then the pc would show a connection but it only went to the router not through to the web.disconnect your modem reconnect then do a reconnect on the pc
Aug 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Problems with Belkin Wireless G Plus MIMO Router
- Nope, it is not possible, you may need an Access Point to do it.
Mar 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Slow Internet using Belkin Wireles G Plus MIMO
Try setting the MTU size to 1400 and also check if there's any firmware update for it if there is update the firmware.
Hope it help
Apr 22, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin Mimo Router
If you're connected to the router with excellent stregth then the problem most likly lies in the routers connection to the internet. Check your DSL, Cable modem and make sure the connection to the "Internet" port on your router is good. Try switching out the Ethernet cable if nessciary.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless problems
hi sir
when u r trying to connect it with urs gfs laptop
make sure u type in the correct security wep key
thank you
mike
Jan 18, 2008 | Belkin (F5D9230-4) Wireless Router...
No connection to internet
What version of windows are you running? 98, 2000, XP, Vista?
Nov 15, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
166 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
