Question about PSB Alpha Sub Sonic 1 Speaker
Hello i was given a psb alpha subsonic 1 sub. I have a jvc# rx-6032v reciever .The sub. that came with the jvc has L -R rca jack low inputs. The psb has L-R scew-to-squeeze the wire terminals that are high input. It also has high output to speakers with the same terminals .And, finally,it has L-R rca jacks for input from preamp. The receiver has only one rca output for subwoofer .How do i hook it up together ?
4 Suggested Answers
SOURCE: PSB Subsonic 6i
Check the power cable.
Posted on May 24, 2008
VOTIT
  • 2071 Answers
SOURCE: HOOKING UP THE SONY SA-WM20 TO AN AUDIOPHILE PREAMP
Just click and choose whatever connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Sep 02, 2008
SOURCE: How do i connect a psb subsonic 3 to a luxman
You can Hook the sub up to the b speaker channel
Posted on Feb 04, 2010
Can I use a JX-S900 Y/C separated I/O to run two subwoofers out of same reciever??
Yes, on two conditions:
1) the JX-S900 needs to be a proper matrix switcher. It has to have the ability to route 1 input to more than one output.
2) the sub signals need to be low level RCA/phono, and not high level speaker wire connections. That's not just about the type of connector. It's about the signal going through those wires. A low level RCA/phono sub connection conducts a maximum 0.7 Volt. A speaker wire connection can transmit 30 Volts! If you put 30 Volts in to a line level switching device such as the JX0S900 you'll fry it.
Provided that the above two criteriia are both met, then yes it will work.
  • Connect the AV receiver's sub out to Source 1 - white RCA phono.
  • Connect the two subs mono LFE Left input (white RCA) or the single black RCA/phono inputs to the JVC's outputs 1 and 2 - white RCA/phono.
  • Set the source routing: input 1 goes to output 1 and 2
Sep 17, 2014 | Audio Players & Recorders
How can I hook up my jvc rx-6018v to a gemini xga-2000 amplifier?
you can do it a couple of different ways, depending on what you're trying to do with your set-up.if you're trying to do something different than what I describe here, add a comment.
for independent volume control (each unit contols volume to a set of speakers independent of each other) use the rca 'tape' out of the jvc into the rca inputs on the back of the gemini.this puts a stereo signal from the jvc to the gemini. if you want your gemini to power your subs, get an rca y-splitter (single female to double male) and a single rca cable, hook single rca cable to sub out of jvc, connect y-splitter to gemini rca inputs, and single rca to y-splitter.
Mar 05, 2013 | JVC RX-6018V Receiver
Trying to hook up a velodyne dd 12 sub to the unit. Please direct me to the correct way to do this
I have the same setup. Use 1 pair (Left/Right) RCA to RCA cable. Connect from Velodyne "Input" (left connectors) to Yamaha SubWoofer #1 Preamp output. Make sure you have the sub's volume (left knob from back) very low (full counter clockwise is "Min") until you are setting up the audio balance in your house/room. Set Low Pass cross over to 80Hz, Phase switch to 0, subsonic to 20Hz, X-over to "IN", Power to "auto"
On Yamaha RXV1 remote control, go into speaker setup and turn on Sub and any other speakers you have connected.
Warning!! do not turn up volume near a china cabinet while you are watching a movie. Everything will walk off the shelf.
Jan 31, 2011 | Yamaha RX-V1 Receiver
I have no green power light on my subsonic 5i which screws do i remove to replace a fuse inside
Make sure you the plug eorks before you do anything. Plug in a lamp or something. The fuse is inside where you plug the input.
Sep 01, 2010 | PSB Alpha Sub Zero Subwoofer
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Mar 31, 2009 | Yamaha RX-V363 Receiver
Connecting Powered Subwoofer to a Receiver
you will need a line-level converter to use this subwoofer- it is a rectangular-shaped box with wires coming out on one end and red-and-white RCA plugs one the other. The end with the wires coming out will hook to the receiver, and the other end will need to plug into the sub.
Feb 20, 2009 | JVC Audio Players & Recorders
I have a JVC rx-6032v receiver and I have a fiber optic audio cable going from cox cable box to receiver, still not getting sound, is there a setting on the receiver that I need to set in order to get...
yes, you must use the setup menu and assign the optical input to the input you are using. Some receivers have a "input mode" switch. If this one does, you only ned to press it until it says "optical". If you have a owners manual, it will decribe all the settings that need to be made to accomplish what you need.
If you do not have one, I have uploaded one to my website for you do have. It will only be there for a limited time before I remove it, so get it quickly. You need Adobe Reader to read this, so if you don't already have iton your computer you can download it free here:
http://www.adobe.com
Here is the link to the owners manual:
http://www.get1here.net/rx-6032v-ownersmanual.pdf
I would appreciate a "FixYa!" rating for this free information and manual. Let me know if I can be of any further help.
Dave
Jul 12, 2008 | JVC Audio Players & Recorders
Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Nov 02, 2007 | Yamaha RX-V1200 Receiver
PSB Alpha Sub Sonic 1 Speaker Logo
117 people viewed this question
Top PSB Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Terry Weaver
Terry Weaver
Are you a PSB Audio Player and Recorder Expert? Answer questions, earn points and help others
