Question about Crosley CW5000 Front Load Washer
I have a crosley cw5500w top load washer, it is filling very slowly despite adequate water pressure. Is there an inline filter that could be clogged?
  • 347 Answers
Yes their are inlet filter screens where the fill hoses hook up to the washer if you shut off the water at the wall and remove the hoses at the unit and look and you will see them carefully pop them out and clean,,,And you will be back in operation
Posted on Sep 16, 2010
I have a toshiba washing machine model :aw-sd130sb: error code ec5. But this time solve the problem?
Ec5: Overloaded or insufficient water.
1. Your load of clothes is too large. Wash smaller loads.
2. If the water inlet valve is defective, the wash may fill slowly or not fill at all. The water inlet valve requires sufficient water pressure to function properly. First, check the water pressure to determine that it is adequate. If the water pressure is adequate, see #1. try cleaning the screens inside the water inlet valve hose connection ports. If the washer still fills slowly, replace the water inlet valve.
hope this helps
Jan 09, 2018 | Washing Machines
ERROR CODE 1e
An IE error code signifies that the washing machine is filling with water slowly or not at all. This can occur when water supply taps are not fully open or the water pressure to the tap or house is too low. Other possible causes are kinked, pinched or bent water line hoses, or clogged water inlet filters.
TIP Make sure the water taps are fully open.
Make sure the hoses are not kinked or pinched. (Use caution when moving the washer.)
Clean the inlet filters.
Check another faucet in the house to make sure your household water pressure is adequate
You may try the following link, too http://www.lg.com/us/support/answers/front-control-top-load-washers2013/control-panel
Sep 19, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My fuzzy logic LG washing machine, is no longer spinning or washing the clothes its showing error
Check another faucet in the house to make sure your household water pressure is adequate.
Reference:
May 19, 2015 | LG Washing Machines
CROSLEY WASHER CAW9244XQ2 NO FILL
Hello Greg Aguilar - Are the house valves turn on fully? Washer not filling with water can be caused by many reasons. Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Since you have just recently purchased the washer, I strongly suggestion contacting the manufacturer for a listing of certified techs that can move forward accurately.
Dec 09, 2012 | GE WBSR3140DW Top Load Washer
H20 fault is flashing on my hotpoint washing machine all connections are correct but still the machine will not fill with water?
H20 does indicate no fill.
Make sure that that there is an adequate supply pressure to washer, check that there are no kinks or restrictions in hose/s.
To be certain if you have an adequate supply turn off water valve to washer, disconnect hose and hold the hose into the sink or a bucket, turn the water back on, and see what the pressure is like..
If ti is too low, thjn the valve will not operate properly..
If you are satisfied it is o/k then it is quite likely a valve fault, also check the filter built into the valve inlet.
Dec 08, 2009 | Hotpoint Aquarius WD640 Front Load...
Slow Cold Water Fill
There is possibly a filter screen in the hoses as well as the water valve.Check the hoses for screens.Occasionally the water valve will deteriorate inside and must be replaced.
I am on a water well and have the same problem. This weekend I installed a inline filter purchased from Lowes. It has stopped the sand and silt problem. You will have to buy one extra water hose to do this yourself.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
I have a maytag washer # LAT 9593 , washer fills with water very
Take off your hoses and check filters for sediment build up. If this is ok, you may need to replace the water inlet valve.
Feb 04, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Cold water fill cycles very slowly on and off during fill
Replace the cold inlet valve, it is obviousl faulty, unless of course it has a filter, if so, then remove and clean.
Plz rate my solution
Thanks.
Jan 16, 2009 | Kenmore 22422 Top Load Washer
Water very slowly fills Whirlpool washer
Check the screens inside the water valve. They get plugged sometimes. Also check both ends of your hoses. When installed most companies put screens or screen (1) in the cold water line at the valve.
Nov 18, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a whirlpool front end load washer and have been getting an f20 error message. we checked the inline water (fine), also the screen inline to the washer (clean). When starting a cycle, we note...
code indicates pressure switch not tripped after 6 min...slow fill,water siphoning out(drain too low or too tight in standpipe)possible pressure switch under top right side
Sep 11, 2008 | Whirlpool Washing Machines
Crosley CW5000 Front Load Washer Logo
319 people viewed this question
Top Crosley Washing Machines Experts
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
