Question about Harman Kardon Audio Players & Recorders
RE:SUB-TS6, ME0315-03682. After a recent move the subwoofer works but fades right away. A short time later it will work again then fades away again quickly. Please advise
  • 39 Answers
SOURCE: subwoofer
first isolate trouble by giving audio signal to your power sub. by your finger.you know when we put our finger on input signal the noice is amplified and you can listen sound.if nothing is noticed on sub that menas sub has problem.
Posted on Dec 18, 2007
SOURCE: Sub Woofer Won't Work
mbruno did this work? I have the same issue
Posted on Jan 16, 2008
pjstanley
  • 185 Answers
SOURCE: subwoofer stops working after awhile, but only one
it sounds like u blew them or the voice coils could be messed up here is one way to check take the woofer out of the box and look at the coils it should be ornge and then smell it if it smells like fire it might be going bad thats the reson it is frezzing like that let me no what happens and please rate me
Posted on Apr 07, 2008
SOURCE: Onkyo 805 sub hook up problem
Looking at the back of the sr805, there is a second subwoofer output, this one is the preout. 4 rca jacks to the right of the non-preout subwooker. Moved it, and all works now.
Posted on May 15, 2008
SOURCE: Sony Active Subwoofer noise
need a schematic for a sony sawmsp1 active subwoofer....anyone????
Posted on Jul 17, 2009
Definitive Pro-Sub 1000 subwoofer replacement fuse.
Fit a 3 or 2.5 anything lower, if you can get away with it, but nothing higher.
However the chances are that it blew due to an overload, often caused by a shorted semi-conductor acting like it was a piece of wire. So even fitting a smaller one and it blowing again doesn't mean it's due to the rating.
Jun 25, 2010 | Definitive ProSub 1000 Subwoofer Speaker
Short in subwoofer wire - Altec Lansing computer speakers & sub
yes, you can splice the cables and put on a new connector, goto radio shack with the old connector and im sure they will have one you can splice right onto it. ive done this many times with varios equipment "headphones speakers etc" it may take a couple of tries to get the wiring right but if its just one speaker there will most likely be just 2 wires, if you wire it up and it doesnt quite sound right, wire it the other way. speakers will work wired backwards but wont sound quit right so if it doesnt, rewire it and it should. good luck and i hope this helps!
Jan 15, 2010 | Altec Lansing ADA 885 Computer Speakers
Carver d12 subwoofer making humming sound
check your rca ground on the woof or the receiver you have a bad ground on one
Oct 09, 2009 | Electronics - Others
Subwoofer not moving
check you RCA leads and wiggle them and see if the sub starts working also check the fade on the head unit and the gain settings on your sub
Mar 13, 2009 | Car Audio & Video
Sub help
there no point getting it fixed cos it wiil do the same thing again later on down the path.
Jun 24, 2008 | Jl Audio 13W7 Car Subwoofer
Amp and Stereo hooked up, no sound coming from the sub
It sounds as though either the sub or amp is blown. When an amp blows quite often the light will still light, but the internals are trashed. The only surefire way to tell whats going on is to use a Digital Multi-meter to check the impedance of the sub, and the voltage at the amp. You can get a multimeter as cheap as $10 at most autoparts stores, Radioshack, Sears, etc...
Also, always post brand names and model numbers, because more info equals more help.
Apr 30, 2008 | Car Audio & Video
The circuit that should be turning the sub on and off based upon the presence of an audio signal is not working correctly and the sub is trying to reproduce 60 cycle hum. The unit needs service.
Dan
Mar 09, 2008 | Audio Players & Recorders
12" kicker l7
It sounds like the "flex" surrounding your SUB has not been flexed properly. When it comes to SUBS, if you can't fix it in the 1st hr. Its better to replace em.
Try pushing on your SUB repeatedly for about 3-5mins. Working the "flex" on it. If there still is not give in it, time to replace.
Feb 11, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Talked to tech support at Onkyo and there seems to be two (2) places you can hook your sub up to. I placed mine in the wrong slot. So please double check where you placed the sub connection.
Jan 05, 2008 | Audio Players & Recorders
SubWoofer
Sounds like your original and this sub have bad amps. The amp for the sub is not the same as the amp for the other speakers. The old unit has a dead amp and this new one is on the way out. (Pulling too much current on high bass)
Mar 30, 2007 | JVC TH-M505 System
190 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
