Question about Acer Aspire™ T180 PC Desktop
Computer turn's off automatically
i have a problem with my pc that it shut's down automatically due to some power failure,so as far as my knowledge is concern that it happens due to smps problem,because it is not running more than 2 or 3 minutes,and it is producing some kind of music tone,so please help with the problem,whether i should change the smps or the hardware installation of the pc is not correctly.
    Guru:
  • 458 Answers
It might be a virus or trojan, get new and updated anti virus and instal on your pc
Posted on May 18, 2008
Dell inspiron m5030 keeps turning it self off
This problem is due to the following:
  • Your computer is overheating
  • Critical problems with your registry
  • Critical state of the system files
  • Hard disk data cable and power cord are loose
  • RAM is not properly connected
  • Problem with the SMPS connections
For fixing computer automatically shuts down issue, you shall remove the motherboard and reconnect all the connections. Take help of a hardware expert while doing the task.
The solution to fix computer automatically shuts down is to download and run a good and reputed Registry Cleaner software, use RegInOut to fix this problem.
Jan 03, 2012 | Dell Inspiron M5030 Laptop
Computer keeps shutting down
Sep 16, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Dell Poweredge 840 shutdown automatically
Hello
This error mostly comes with the failure of processor fan, overheating of processor shuts down the system due to processor's protection. You need to check the fans and replacement is recommended.
Hope this helps
Jan 31, 2011 | Dell PowerEdge 840 (becwmk1_2) Server
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
My computer sarts automatically when I want to shut down
it seems that your computer restart when you attempt to shut down. this problem due to short in power button in the cabinet. open the right side of the cabinet.most probably there will be red&white twisted thin wire from front panel for power, the colour may vary manufacture to manufacture.be carfull with it. see at left bottom of your dell PC mother board the wire will lead to two pin specifying power, restart, hdd etc.. short it with your screw driver. if system turn on then it is problem with switch replace it or if it not work then reboot the os.
Oct 24, 2009 | Dell OPTIPLEX 745 PC Desktop
Remote access to dial-up connected computer
https://secure.logmein.com/home.asp?lang=en
Try this.Set it like after reboot it automatically starts.
Once it comes up you will be able to connect again.
Please rate me if you like my solution.
Mar 12, 2009 | Microsoft Windows XP Professional Upgrade...
Desktop Will Not Turn On
shut the tower off or unplug it form the back for a few minutes
plug in back in and then try to turn it on
you may have a power supply failure
let me know what happens
Jan 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
HP Desktop Pent 4 randomly shuts down and restarts on its own
That is a power failure, please try change the power supply..or test the voltage in the wall outlet if it rate 220 volts if not then power supply is the main causes. Sometimes the software's got conflict due to virus infections.
try to scan your computer with a potent antivirus maybe it help.
melnavz
Oct 23, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Battery problem????
Check the power plan of your operating system!
blow a can of air into the fan and sink assembly if you think its a problem due to over heating..
Take out the battery and clean its terminals on the battery and the in the laptop too..
If its restarting automatically then go to My computer>right click> properties> advanced> repair/recovery > uncheck the box for automatic restart and do a clean boot..
regards,
Ronald
Aug 18, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Computer will not start
Choose Last Known Good Configuration. If that doesn't work, choose Safe Mode and then do a system restore to roll back your PC.
Any further questions, please use the comment box below to respond. Thanks.
Worldvet
Jun 16, 2008 | HP Computers & Internet
Acer Aspire™ T180 PC Desktop Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
