Question about Garden
How to replace purge on echo cs 3000 - Garden
  • valleygrovel Sep 17, 2010
    i did not see any solution posted
  • 1,041 Answers
I just answered this question the second time you posted it.
Thanks! Jim
Posted on Sep 16, 2010
  • Jim Parker
    Jim Parker Sep 17, 2010
    Thanks for accepting my bid and Thanks for the rating!. If you should ever have any questions about "Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building
How do I replace the primer bulb on an Echo cs-346 chaln saw?
The part number is 12318139130 and this youtube video covers this part's replacement.
http://www.youtube.com/watch?v=cnzag2RqhRo
Jul 12, 2014 | Echo Garden
How to replace a primer bulb
Small engine shop will have that part u will need make ,
model , s/n some small bolts out with old in with the new good luck
May 29, 2014 | Echo Cs300 Cs 300 3000 305 3450 Top Handle...
How do I replace the purge pump on thr Echo chain saw model CS 3000
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Jun 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
ECHO CS 3000 chainsaw-while idling, shuts off if held on an angle
The idle speed screw may be set too low--adjust so that the chain stops moving, but the engine keeps running. Drain the fuel tank and see if the filter falls to the lowest point of the tank whatever the position. If it doesn't, replace the fuel line hooked to the filter as it may have lost flexibility. Hope this helps!
Apr 11, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How to replace primer bulb on small echo gas chain saw.
I just replaced the primer bulb on my Echo cs-305.
I didn't find the parts list too helpful.
It's easy. All you have to do is remove the air filter and look at the existing bulb from the bottom-- you can reach in with a screwdriver and pop the 'feet' holding it in place off their catches. When I put the new one in, I attached the tubes using a pair of needlenose pliers.
Apr 04, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Dropped my echo cs-3000 ignition coil wires came apart and wires to on/off button. which wire goes where?
EchoUSA
http://www.echo-usa.com/faqs.asp
#2,
then line 2 "Operator's Manuals/Parts Catalogs/etc."
Click "CS3000"
Toward the botom is the "Parts Catalog", choose the "Ignition, Starter Assembly" detail.
Item 4 connects between the coil and the on/off switch.
HTH
Lou
Nov 19, 2009 | Echo Garden
How do I change the primer bulb on my Echo CS-3000 chain saw
The IPL for an Echo CS-3000 is here:
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
See page 8. There is no shop manual offered, you will need to interpret the pictures. Didn't look to difficult. GL
Lou
Sep 06, 2009 | Echo Garden
Purge pump removal
By studying an exploded parts diagram found online, I determined that it snapped out the top before the bracket slid out the front.
Jan 29, 2009 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
