Question about FrancisFrancis! X1 Espresso Machine
I have a 2001 Francis Francis X1. Replaced boiler a year ago and it work great. Termal fuse went 3 months ago and I replaced it. Now when I turn machine on it heats very slow and does not go above 60. Steamer switch heats right up without problem. What is the problem?
    President:
  • 1,618 Answers
The thermostat for the coffee is damaged, you will have to replaced it. There are 2 on the boiler one for steam and one for coffee.
Posted on Sep 16, 2010
Francis Francis X1. Why does it work sometimes and sometimes heater trips GFCI?
take it to an appliance repair shop to have it checked out
the trip is working but if you ignore the problem you may get electrocuted
Dec 25, 2015 | Coffee Makers & Espresso Machines
"francis francis" x1 blocked - Fix Suggestions?
You can tell if the pump is working by the noise it makes. Mine got blocked with scale and I took it apart and cleaned out the boiler. It's possible; the boiler is bolted together with standard bolts (metric size). If you've got the interest the Francis Francis is easy to service; you will find a way into each part of it and clean it, and if you do it will work like new.
Jun 22, 2014 | FrancisFrancis! Coffee Makers & Espresso...
My Francis Francis x1 wont heat
You should check the temperature of the water coming out from the machine when it show that is heated. If it is lower than 90 C then the thermostat inside the machine attached to the boiler is need to be replaced. If the temperature of the water is about 90C then the problem is with thermometer, and in this case is only an accesorie since the machine can faction properly and make a good espresso.
May 21, 2012 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis X1 Popping noise - stopped working
Hi There are a couple of things that could have happened. The fuse could have blown, but you wouldn't get a pop usually. The main board could have blown, that will pop. There is a hole below the steam arm. up inside there is a screw that you can loosen. Then you can unscrew the steam knob. There are 4 screws on the bottom side of the cover that will allow you to remove the top. Make sure that the machine is unplugged.
Feb 13, 2010 | FrancisFrancis! X1 Espresso Machine
Francis Francis fuse defective?
Hi
If you have power its not likely the fuse. It could be the heating element or the board.
Jun 16, 2009 | FrancisFrancis! X5 Espresso Machine
Low temperature
I had the francis francis examined.  It is indeed the boiler, a $200 fix if you could get the part.  Francis Francis X1 is now a brick!
Dec 19, 2007 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis! x1 leaking
Well, to state the obvious, you should call Francis! Francis! at 1-877-854-4141 and ship it to them for repair. It's unlikely you can perform a fix yourself. Have you tried opening the machine up? I got PDFs of diagrams and part lists, which I obtained by calling them at the number quoted above. Good luck! Stephen
Dec 13, 2007 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 Espresso Machine Logo
411 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Joe Lalumia aka...
Joe Lalumia aka...
Jim Goldsmith
Jim Goldsmith
billconfused
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
