I have an FP45 model pellet stove manufactured by Stove Builder International and I am having problems starting it. First I push the power button and it comes on for about 2 seconds and then I get a P message and it stops working. I have tried to reset, cleaned it and still not working. This stove is 2 years old, but new to us. I have read the manuel but can't figure out what could be wrong. Please help. Thanks
  • 1314 Answers
SOURCE: Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Posted on Jan 01, 2008
koolbreezes
  • 540 Answers
SOURCE: we have a harmon p61
The only thing that will turn it on is the thermostat setting! Check your temperature setting for temp. in the centigrade or farenheit! Tank-you-very-much!
Posted on Aug 28, 2008
SOURCE: St Croix pellet stove: pellets drop
http://www.jaygaulard.com/blog/2009/01/18/how-to-clean-out-a-st-croix-prescott-exl-pellet-stove/
Posted on Feb 24, 2009
protek480
  • 1723 Answers
SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 01, 2009
SOURCE: Cannot reset clock on my electric stove after a power failure!
Unplug the stove for 10 minutes, then plug it back in.
This should resolve your problem...
Posted on Sep 29, 2009
Heilsa Pellet Stove Manufacturers Information
pellet stove tp440 Pool & Spa Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > pellet stove tp440
Pool & Spa Heaters pellet stove tp440 questions and answers. ... for a manual orinformation on this stove it is an older stove we just don't know how old. ... heilsa pellet stove model qcps-28000 my pellet stove is smoking how to change ...
General Infrared Sauna Heilsa Sauna Supplier, Find Best ...
www.alibaba.com/general-infrared-sauna-heilsa-sauna-suppliers.html
Suppliers who can match your search. .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter .... Infrared sauna room,Portable steam sauna,Infraredheater,Pellet stove,Clothes dryer ..... updates on topics such as trending hot products, buying requests and supplier information - sent directly to your email inbox!
Good Quality Far Infrared Sauna Supplier, Find Best Good ...
www.alibaba.com/good-quality-far-infrared-sauna-suppliers.html
Suppliers > .... Outdoor Spa,Sauna Room,Jacuzzi,Swimming Pool,Sand Filter ...Infrared sauna room,Portable steam sauna,Infrared heater,Pellet stove,Clothes dryer ...compare heilsa infrared sauna with good infrared sauna accessories ..... buying requests and supplier information - sent directly to your email inbox!
Jan 06, 2016 | Pool & Spa
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
Does anyone have any information on the Pine Ridge 500 wood stove? I'd like to know who the manufacturer is and what the EPA specs are.
PDF]installation and operation manual - Wood Pellet Stoves ...
www.pelletking.com/...stove-manuals/whitfield-advantage-iit-pellet-stove...
Services) and the listing mark is Warnock Hersey. Testing: In accordance ... The assembled pellet stove model Advantage II-T C FS and. Advantage II-T C INS ...
[PDF]INSTRUCTION MANUAL - Ignite Dealer Portal - Regency ...
manuals.regency-fire.com/getattachment/.../R12-R14-R16-Manual.aspx
Tested by Warnock Hersey ... LISTED FACTORY BUILT FIREPLACE ACCESSORY HEARTH STOVE ... it is important that you read this manual throughout.
Nov 01, 2015 | Home
What is a 5 u code on a pellet stove
New Stove Auger not moving shows S U in display ' Hearth.com ...
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Nov 25, 2010 - 25 posts - ‎6 authors The letters "S U" mean the stove is in "Start Up mode. ... At this point load the stove w/pellets and hit the start button again. ... Shows SU again and settings are at 5 and 5. still no auger movement, not even the slightest bit. ... The E-0 code is the no error errorcode and stove will enter normal operation which ...
Oct 03, 2015 | Pool & Spa
We have a heilsa pellet stove model#QCPS-28000 ,its dropping pellets to fast ,how do I adjust the feed.
  1. SET THE AIR INLET DAMPERS
It is not possible for the manufacture to factory set your stove to work properly without some adjustments. The dampers help control the amount of airflow supplied for combustion.
A damper PUSHED IN all the way, maximizes concentrated air flow to the burn pot. This will maintain a robust fire.
The Auger timing is designed to be run, in most conditions, with the dampers closed.
In some areas/conditions, it mybe necessary to adjust the damper open slighty in order to slow down the flame and allow the pellets to keep pace with the rate of burn. This should be monitored closely to ensure you have the propoer feed rate established. If dampers are opened too much, the rate of burn will be very slow and the pellets will build up.
This setting needs to be fine tuned to according to your location and elevation. It is recommended that you start with the dampers pushed in to start.
Feb 20, 2013 | Northern Tool and Equipment Pellet Stove -...
I bought a house with a Warnock Hershey eclipse pellet stove. Am having some problems. Where can I find a manual?
Warnock Hersey is not actually a manufacturer's brand, but a certification. You can find more info here: http://www.wood-stove.org/firebelly-stoves.html .
or you could try this link:
http://www.pelletking.com/pellet-stove-manuals/Whitfield-Advantage-IIT-Pellet-Stove-Manual.pdf
I hope this helps you out & if it does please don't forget to rate me, kind regards, Paul
Sep 14, 2012 | Cars & Trucks
I clean the stove as discribed in the tape i got w/ the unit. But, in about 8hrs. burn time , fire box is over full and feed tube is backed up. I have air wide open and lowest feed setting. Any ideas . If...
That is an old pellet stove. One problem may be that you have recently switched the type (Manufacturer) of pellets. Not all manufacturers make the pellets the same way. So you would have to re-tweek the auger feed an the air intake to the stove. If you no longer have your Owners Manual try searching Google for the Manufacturer and contact them for advice. But, I suspect that the model you have is no longer manufactured, as it does not meet the current EPA standards for emissions.
Jan 27, 2011 | Heating & Cooling
Trying to hook up a RTH2310B thermostat to a wood pellet stove with only two wires.. How do I know where to connect them too?
Hey Brad432, this is what i did with the same RTH2310B thermostat and my harmon stove. You must have the heat sensor that plugs in the back of the stove to start with. Take your new wire from the stove to your thermostat, red to rh, white to one side of your sensor then other side of sensor to W on your thermostat. On your stove side set your room temp as high as it will go and let your programmable thermostat set the room temp. Works good for mine. Good Luck
Nov 01, 2010 | Honeywell Focus 6300B 5-2 Days...
What do you need to do to put a woopellet stove pipe thru wall
I'm confused by your question. If you are asking what is involved in installing a pellet stove well it varies greatly from model to model. Generally speaking, most pellet stoves will horizontally terminate behind the stove itself as opposed to running thru the roof like a woodstove does. Pellet stoves require the use of electricity for numerous functions, one of which is power venting thru this rear terminated pipe. As far as clearances to combustables, you will find that pellet stoves are very forgiving in that department, with minimal clearances required. Once again all stoves are different and they all are rated indepentently so my best advice to you is find a quality pellet stove dealer and go in and see them. They will be more than happy to answer your questions. Avoid the big box stores as they have pellet stoves at a good price but offer NO service or installation and believe me, I am in the business, you will need professional service at some point during the life of your stove so don't save a couple bucks by going cheap. You will be happier for it down the road. Good luck.
Mar 12, 2009 | Napoleon Auburn Pellet Stove Heater
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
