Question about Cycling
What is the proper replacement derailleur hanger for a Colnago Cristallo and where could I get one?
    Genius:
  • 1,788 Answers
Go to a bike shop that specializes in Colnago or one that is willing to order that part for you. You may find one on ebay but it is doubtful. Where did you get the bike? that shop should have them. Good luck
Posted on Sep 16, 2010
Will this derealler hanger fit my Colnago Ace 2013
Jose , It looks close if not perfect. The best way to find out is to install it and test it. I would just check the widths of the replacement before that though..
Mar 19, 2014 | Colnago Mech Hanger | Suits...
Mongoose Maxim 26" mens bike-
If it's "broken" or even bent it will have to be replaced. Your frame or derailleiur hanger may also have taken a fatal hit.
You should consult a Bike Shop.
If you still want to DIY you'll need to obtain some specialized tools and skills.
http://www.parktool.com/blog/repair-help/rear-derailleur-hanger-alignment
http://www.parktool.com/blog/repair-help/chain-installation-derailleur-bikes
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Jul 09, 2011 | Cycling
Mongoose 21speed spear derailer is bent. bought at yard sale 60.00 dont want to put much money into. what is the best way to fix this. how much? Want to use as spare bike. it is rideable but how long....
A new Rear Derailleur may cost more than you paid for the bike. But is IT bent or is it the derailleur hanger?
Search the web for "fix bent derailleur"
Steel frames can be re-formed but not most other materials.
Someone in your club should know how to deal with it and maybe even have an old derailleur hanging around.
Jun 30, 2011 | Cycling
Derailleur hanger for connondale flash carbon 4 2010 i think the part number is kp 121
What's the question?
Use a Search Engine for it and you will find many for sale. Also check eBay.
Go here and find all the documents on hangers...
http://www.cannondale.com/manuals
Jun 15, 2011 | Cannondale Derailleur Hanger For Rear...
My sram x-7 derailleur hanger broke and i bent the derailleur. I've replaced the hanger and re alligned the derailleur but i went to bolt the derailleur back onto the hanger but the bolt doesnt seem to be...
You need to replace the main pivot bolt, something (most likely a tab) is broken. This one is best taken to your local bike shop for inspection. There may be something your missing like a crack in the body or another broken part. Link to Manual.
You can also contact the SRAM customer service for support, but they will refer you to a shop to take care of the problem and order any parts on this type of problem.
Dec 14, 2010 | Sram X7 Mountain Bike Rear Derailleur
Colnago C50 with 11 speed choras group set. When changing up to the big chain ring ready to decend whilst still in one of the largest 2 or 3 rear sprockets the chain...
Is the chain falling off to the outside? if it is you can adjust the "High " limit screw on front derailleur. There are two screws on top of derailleur usaully marked with a L or a H.Shift rear to small cog and front on large ring. Slowly turn screw marked H till you see front derailleur move in. When it starts to rub on chain back off 1/8 of a turn. Run the rear up and down a cuople of gears making sure nothing rubs and adjust accordingly . Same with the front. That should do it! Also when changing to the big ring up front you should try to be on a middle to small cog on the rear so you don't get into a "cross chain" situation. When running on the small ring you should be on large to middle on the back. Hope that helps you out.
Sep 13, 2010 | Colnago Freeship Ferrari Cx-20 Bicycle...
Not leting me shift into 3rd gear
Front or rear?
Rear: Flip the bike onto the bars and saddle, then shift into third while turning the crank. Use the barrel adjuster on the back of the derailleur to align the derailleur over the proper cog. If this doesn't work, you may have a bent cog or a bent derailleur hanger. Does it only happen in third? Inspect your third cog for any deviation.
Front: Shift into the small chainring and release the derailleur cable. Pull tight and re-attach. Shift into the big chainring now. If it still won't go, use the barrel adjuster on the shifter co tighten the cable until it does shift. If necessary (because the derailleur will not go to the big chainring on account of a mechanical impedance) adjust the "H" screw to allow the derailleur to move far enough out to shift on to the big ring.
If all else fails, check with the bike shop.
Hope this helps,
matt
Sep 19, 2009 | Pit Cycling
The chain is rubbing on the rear tyre when its free wheeling. what do I do?
You may have too large a tire on the back for the bike. However, if the derailleur hanger is bent, this could also cause the problem. Flip your bike over onto the bars and seat and make sure the derailleur alignment is good (vertically and longitudinally straight). If the derailleur hanger is straight, then you will have to use a narrower tire in the back.
Jun 30, 2009 | Mountain Shimano Tourney 6/7 Rear...
Cycling Logo
71 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
