Question about Ovens
Chambers Imperial Majesty electric double oven: my clock is making a lot of noise and is not keeping proper time...where could I buy a replacement?
3 Suggested Answers
EllaWatson25
  • 725 Answers
SOURCE: Need Chambers Oven clock/timer unit, model #GBO-244
I can get you one. Please call me at 9728590929 and I will be happy to find one and ship it to you. Hope this helps! Ella
Posted on Aug 22, 2009
I NEED 2 KNOBS-1"
Posted on Oct 07, 2012
Candy fl 134 x uk , single oven ..... oven works fine ... clock/ timer is dead and keeps making clicking noise , when not in use i power it off ... do i just need to replace the clock ???? Thanks roy
[n 75 years I have never heard of anyone powering off an oven when not in use . those little clocks do not use enough electric to worry about waste
Feb 25, 2017 | Candy Ovens
I have a Chambers majesty double gas oven that needs new thermostats and clock is not working. I would be happy even if its a universal thermostat
Get any and all numbers you can find from the original controls. Also make a note as to the length of dial shafts, direction they turn, shaft size and "flat" location when in off position and the temperature range and whether high to low or low to high.
Then go to this site and search for exact or something that you could live with. . . . http://www.uni-line.com/modules/catalog/SearchResults.aspx?catName=19145&pID=18668&mode=categorysearch . Hope this helps!!
Jul 31, 2014 | Kenmore 30464 / 30465 / 30469 Gas Single...
How do you get the ge profile oven time set to not on military time. we push clock time and the time, and it defaults to military time.
I don't know this particular model but on a lot of different brand stoves/ovens the clocks only work on military time. I have encountered many of these and they are manufactured to work on this time only. Unfortunately I have one sitting in my kitchen!
Mar 13, 2011 | GE Profile JTP56 Electric Double Oven
Error Message F2 E6
Perform the following actions to fix your error:
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'Upper Cancel key ' function and wait for 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thank you !!
May 30, 2010 | Whirlpool RBD305PR Electric Double Oven
How do you set the analog clock?
My eaton viking imperial stove came with the house and no manuals. The timers are digial, how do i set them
Oct 20, 2009 | Viking 27" Professional Select Built-in...
Aug 20, 2009 | Ovens
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Mar 24, 2009 | Ovens
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
Mar 16, 2009 | GE JKP27 Electric Double Oven
Keep having to replace element
Not neccesscarily a problem with oven, as it is quite a common fault with fan ovens.
You could make sure that the fan is running properly, and is free to turn, and that the fan blades are not covered in grease etc',
Make sure that oven door seal is o/k, as hot air escaping here will lead to longer running times.
Plz rate this solution.
Thanks.
Dec 10, 2008 | Zanussi ZHQ575 Electric Double Oven
Jenn aire
Maytag-Maycop-Magic Chef-Jennair-Admiral
Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 10, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Ovens Logo
548 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
