Question about Telex FMR-200H Professional Microphone
ProStar UB12. When I turn on the wireless, I get occasional static that is irritating to the point I cannot use it. Is there a fix?
I had the same problem. Mostly, when using near energy saving fluorescent lighting. I would receive high static, especially when the mic was off. We were using it indoors & usually no more than 200 ft from the receiver. I opened it up, resoldered some poor solder connections, sprayed contact cleaner on the squelch & volume controls, but still had the problem. What actually resolved the issue, was turning the squelch control (thru back panel) fully clockwise & completly lowering the antennas aimed horizontally to the rear. If you are using it outdoors, you should not have interference from fluorescent lighting, but may need to raise the antennas if operating from a greater distance.
Posted on Oct 08, 2010
Testimonial: "Good advice and it worked"
Canot connect to 192.168.0.50 on a DAP-2695 wireless access point
It is extremely unclear from this what you are trying to achieve and what machine you are on. If the machine you are on is a desktop connected straight to the access point it may not have a wireless adaptor so you may see nothing like that in network connections. Cant comment on setting a static address without understanding why you are bothering with that and not just picking up a DHCP address from the router.
Jul 09, 2014 | D-Link AirPlus Xtreme G DWL-2000AP...
How do you get the RX icon to turn off? The unit just has a contant fuzzy buzz.
RX represents "receive" This indication will be present whenever the speaker is producing audio. The "buzz" you're talking about is probably static, and is technically audio from the speaker. To silence the "buzz" adjust the squelch just until the speaker falls silent. The RX indication should be off at this point.
It is important to note that the squelch is designed to keep the speaker silent until a signal is detected. You adjust the squelch based on the level of static at a particular time and at a particular location. The static level may change depending on those variables. If you adjust the squelch well beyond the point that the speaker is silenced, you may not be able to hear transmissions or calls to you unless the caller's transmitter is physically close to you. This is why the squelch should be adjusted only until the static is stopped and the speaker is silenced.
I hope this helps and good luck!
Apr 30, 2012 | Radio Communications
I lost my cd for setup ipls help me this is my serial number of my netgear 1um8977f03f04tnx
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually 192.168.1.1, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point's DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to 192.168.1.99.
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL: http://192.168.1.99
  9. Connect one of the wireless router's Local (LAN) ports to your existing network
Feb 21, 2011 | NetGear WGR614 Wireless Router
Internet connection is fine when my PC's connected directly to the modem. The router connects fine. But won't let the wired PC online. Under the "status" bar the "router" tab won't show the correct...
here are times when there is a need to connect a wired computer to an access point in order to set it up. To connect a wired PC to a Linksys access point, follow the steps below. Step 1:
Connect the PC to the Ethernet port located at the back of the access point.
Step 2:
Assign a static IP address on the computer. For instructions, click here.
NOTE: To assign a static IP address using Mac, click here.
The Access Point can be configured in four different modes:
  • Access Point
  • Access Point Client
  • Wireless Repeater
  • Wireless Bridge
The Access Point mode allows wireless clients to connect to the access point and routes traffic between the wireless and wired interface. Use this mode to create a standard wireless Infrastructure network. For instructions, click here.
The Access Point Client mode allows this device to act as a wireless client. You can connect a wired PC to the access point to connect to a wireless router or another access point wirelessly. You can enter the MAC address of the Access Point or use the Site Survey button to select the Access Point you want to connect.
NOTE: The WAP54G will only communicate with another WAP54G when set to the Access Point Client. For instructions, click here.
Sep 05, 2010 | Linksys Wireless-G WRT54G Router
Netgear access point cant open configuration page
Typically you should be using configuration software until a real IP can be setup and you either address it statically or turn on DHCP. As for the gateway and other information, on a wireless gateway, it should all be routed through the network. Also, I think you have to be wired to the WAP to access the config page, I don't believe it can be seen over the wireless connection as a security feature.
Aug 02, 2010 | NetGear WG602 54Mbps Wireless G Access...
Wireless internet connection
Hi there I would tell you why:
1) your DSL speed band only 1.5M and the upload could be lower then 256K speed. that is not avalible to get good condition for more laptop wireless online at same time
2) other thing, your laptop wieless online in your router situation that depends on the laptop wireless card type, high level (faster)card will get more speed band and aganst other laptop.
so you could not setting any more to get improved.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 28, 2009 | Sony VAIO VGN-FW235J Notebook
How can i fix an ip adress conflict?
If you Router has DHCP running then please check that no any computer which you conect has Static Ip configured.
There are few viruses around as well which cause the ip conflicts in the networks...
Nov 27, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Wireless access point and wireless router
Connect the cable from accesss point to a switch or if you have lan slots in wireless router.Make sure that you have to give static ip to the acceess point.
Oct 30, 2008 | Computers & Internet
Dose cisco aironet 1100 support routing
You must use a router to perform NATing to the ISP. Simply use a Netgear or Linksys router and plug your access point into it. You can even use a Netgear or Linksys wireless router with the ethernet ports built into it. Just disable the onboard wireless.
Jul 31, 2008 | Cisco (airap1120bak9airpcm352) 802.11b
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Telex FMR-200H Professional Microphone Logo
256 people viewed this question
Top Telex Audio Players & Recorders Experts
Ben Armstrong
Sam Palermo
Sam Palermo
jairo sanchez
Are you a Telex Audio Player and Recorder Expert? Answer questions, earn points and help others
