Question about Video Game Consoles & Games
The xbox sudenly was not working and a red light came on
  • 4,102 Answers
When only 1 of the 4 green lights that are located around the start button flashes red and the screen flashes an error code number, it means that you've got the Xbox 360 1 red light message.
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
once you have found out if its the hard drive or the dvd drive then this is the part that needs replacing.
you will either need to get someone to do it for you or if you have some idea what you are doing then it is something you can do yourself, always check to see if you have any warranty left and if you do take it back if not then you will need to pay someone to do the work for you.
if you are doing it yourself then take it from me its not easy taking the case off let alone changing the parts so if you are going to do it yourself use google and fine an xbox 360 repair guide and this will then give you step by step instructions on taking the case off and removing any parts you need to remove, this how ever is not easy to do and will void any warranty you have left so double check your warranty as this part will be covered, taking the case of is not easy to do and you can cause more harm than good if you are unsure what you are doing.
i repair these myself and only charge if the problem is solved you never know if its just the dvd drive or if the unit has over heated and caused the dvd drive to fail, if this is the case then it wont be long before you get the dreaded red reing of death, which is 3 red lights lit up
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Sep 16, 2010
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
My xbox sudenly became all fuzy. it startes off all good the in the middle of a game becomes fuzzy again. whats the problem?
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console.......
click here to download repair guide
Dec 21, 2010 | Microsoft Xbox 360 Console
1 red light on xbox no longer works what is
Why are you looking at the red lights. Thats bad.
Oct 31, 2009 | Microsoft Xbox 360 Console
My xbox has three red flashing lights, how can I get it working again?
My sons Xbox had the 3 red lights! It depends what colour of light is showing on your power pack the colour indicates what the problem is! The light will either be red,amber or green, my sons light was amber and that was due to a faulty power pack, Microsoft were very obliging and replaced the power pack free of charge,it arrived in 3 working days! Here is a link that will take you through the different lights and how to fix the problem!
http://support.microsoft.com/kb/907534
Hope this helps, good luck!
Jul 04, 2009 | Microsoft Xbox 360 Console
Red lights
IT MEANS IT OVER HEATED U SHOULD DISCONECT UR XBOX FOR A WHILE AND THAN TRY IT THEY SHOULD B GONE. IF U GET THREE RED LIGHTS THE THING TO DO IS GET TWO STRAWS AND STOP THE FANS TILL THE TWO RED LIGHTS COME ON THAN DISCONNECT UR XBOX FOR 20 MINUTES THAN TRY IT IT SHOULD START WORKING AL U DID U MADE THE UNSOLDER CHIP RESOLDER TRY IT HOPE IT WORKS
Jun 30, 2009 | Microsoft Xbox 360 Console
Three red lights
Follow this steps:
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Good Luck
Apr 03, 2009 | Microsoft Xbox 360 Console
My xbox 360 has 2 red lights and when i turn it on, it only lasts minutes until the red lights appear
its called the red ring of death and it means ur xbox is breaking my friend didnt no this and got the red 3 times and now his xbox wont work let it chill for a couple of days idk if this will work but hopefully it will
Mar 08, 2009 | Microsoft Xbox 360 Console
Xbobx 360 3 red lights
3 Red lights problem is a drawback of Microsoft Xbox 360
Check out the blog post at http://www.fix-xbox360.info/2008/08/23/xbox-360-red-light-fix/ to know more information on fixing your xbox
Jan 07, 2009 | Microsoft Xbox 360 Console
As playing Xbox 360 system shuts off two red lights occurs.
Two red lights mean your 360 is over exceeding the inside temperature. Your fan must not be working at all and your 360 is overheating tremendously. That is what I know about the 2 red lights. Im not sure what to tell you to fix this but to just call 18004myxbox.
Mar 01, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
21 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
