My hotpoint bw12 washing machine won't stop cycling through wash cycles after starting a wash cycle and won't stop clicking through. How can I fix it?
Jimster
  • 240 Answers
SOURCE: Hoover 600M washing machine cycle issue
Sounds like you may have a timer problem. You might be able to pick one up at a appliance parts center. Most of the time, they can be pretty pricey item, if you can even get one for older models. Check EBAY as well, sometimes you can find hard to find parts for pretty cheap. Replacing the timer shouldnt be that hard. UNPLUG the unit, remove the console, which should be held on by screws, the remove and replace one wire at a time back to the timer. Use caution when removing the timer knob, you dont want to crack it. Most knobs remove by unscrewing to the left.
Posted on Sep 05, 2007
  • 1294 Answers
SOURCE: frigidaire washing machine no spin cycle
Check your exit hose spigot, it may be clogged. This is if your filter is all clean.(Refer manual) There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 11, 2008
aborcass
  • 2651 Answers
SOURCE: KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
Posted on May 12, 2008
SOURCE: Washing machine
Normally these spin problems are just a blocked filter, which is located at the bottom of the washer behind a white panel which you can undo with a coin, drain water first, undo plug from hose into a bowl etc then take out filter and clean, hope this helps.
Posted on Mar 09, 2009
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
Stop in mid cycle
washing machine hotpoint hvl211 stops in mid cycle and wouldn't take the conditioner This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 03, 2012 | Washing Machines
My hotpoint wm63p washing machine when in wash cycle works up until the last spin and then u hear clicking and the machine will skip the cycle and stop or sometimes just continue to the next dial cycle..i...
If you have changed the brushes are satisfied that they are fitted correctly, then it can be a couple of possibilities.
1- The motor itself is faulty.Even though it does the wash o/k it is possible the spin winding is faulty.
2- The prograqmmer is faulty.
Make sure the pump is working o/k, and that all the water has drained out, as this would stop it spinning
Dec 15, 2010 | Hotpoint Washing Machines
How do i fix my washing machine interlock hotpoint hvf 344
The door should have a pin on it that pushes and closes the interlock switch. Check to see that the switch is inadjust ment to trip by turning off the water door open and with a plastic rod or a pencil push thru' the hole in the chasis where the door pin goes through and start the machine. If it starts quickly pull out the pencil, unplug the machine and adjust the switch. Plug it back in. It may continue on with the cycle you just started if not better! If not close the door aand start a short cold wash cycle. If it sounds like it wants to start, turn on the water and let it run thru' the complete cycle.
Jun 29, 2010 | Hotpoint Aquarius WF000 Front Load Washer
WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Feb 03, 2010 | Hotpoint Washing Machines
Put clothes in washer HOTPOINT modelWML730 started
TURN MACHINE ON TO FINISH CYCLE THEN RE WASH WITH SOAP ETCH,DOOR WILL NOT OPEN MID CYCLE SAFTY LATCH,YOU CAN TURN PROGRAM TO FINAL SPIN TO EMPTY MACHINE AND FINISH PROGRAM THEN DOOR WILL OPEN
Jan 06, 2010 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine
Nov 12, 2007 | Hotpoint BWM20 Front Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
