Question about Amana ARB8057CSL Bottom Freezer Refrigerator
Refrigerator blowing warm air.
My 2003 Amana Bottom Freezer Refrigerator suddenly is only blowing warm air. I had adjusted the thermostat yesterday for the first time in almost 5 years. I have vaccumed the coils underneath and the vents in the back with no improvement.
  • Sworden Jun 05, 2008
    my refrig is only blowing warm air. I've taken the front grill off and
    vacuumed the coils. I've also taken the back panel off and vacuumed. the fan and motor seem to be running fine. What else should I do?
  • Anonymous Sep 13, 2008
    I have the same problem with my 2003 bottom freezer refrigerator. Should I call a repair person?
    Genius:
  • 1,073 Answers
Check the thermastat with power off remove one wire on the thermastat and read across the two terminals of the thermastat with an ohm or resistance meter if set to highest setting on the thermastat you should get a resistance reading if you don not the thermastat is vad
Posted on May 17, 2008
My freezer is cold makes ice fridge is warm not cold at all
Look for frost on the rear of the freezer, that is a sign of a defrost problem. If the heater or heater thermostat is open then ice will form over the cols and block the flow of air.
Service manual for amana bottom mount
Jul 14, 2011 | Amana ABB1927DE Bottom Freezer...
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
My freezer works but my refrigerator wont stay cold...getting warm. it is 4 years old. what could be wrong?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 26, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer frosts up and refrigerator wont stay cold. Must be defrosted..then works okay until Freezer frosts up again.
The auto defrost timer is faulty , you willhave to check the timer and teh corresponding circuit for worn out wires, bad thermostat or the defrost heaters. These circuits must be checked properly and the concerned spare can be tested for failure or malfunction. Even if the compressor is pumpiing too much to the bottom side freezer this can happen and stall the fcooling to the top section. Adjust the freezer temp lower and increase the blowing to the top section. Please check on all these suggestions and try. Helpful? Good day
Jul 27, 2010 | Amana ABB1927DE Bottom Freezer...
Refrigerator blows warm air and bottom freezer has
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 25, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
After cleaning coils my refrigerator is still blowing warm air yet the freezer is cold what can I do myself to make the refrigerator cold?
There is a small fan which moves the cold air from the freezer to the refrigerator part. Make sure that this fan is working. If it is not turning, the cold air will not reach the refrigerator.
These fans are easily replaceable; however, you probably will have to remove the interior panels from the refrigerator to gain access.
Oct 09, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerator is warm @ 60 degrees and the freezer is still freezing happens every so oftern
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Amana ABB1927DE Bottom Freezer...
Amana ABB2224DES Stainless Steel Bottom Refrigerator is warm however the freezer works fine. How do I solve this problem? I vacuumed the coil and renoved most of the dust accumulation. Is there a way...
check freezer for frost build up and if FAN is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, make sure u didnt turn up freezer control cutting air supply to refrigertor side should be 1/2 feel vent coming from freezer see if you feel any air coming in to refrig.
Sep 02, 2007 | Amana ABB2224DES Stainless Steel Bottom...
Amana ARB8057CSL Bottom Freezer Refrigerator Logo
986 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
