Question about Whirlpool LEB6300 Electric Dryer
Dryer will not dry a load the first time around, it has to go through two cycles to get fully dry. i've replaced the high limit sensor and the vent is clean. what else might it be?
  • Whirlpool Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Sep 17, 2010
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
Jun 16, 2014 | Kenmore HE3 Steam 7.2 cu. ft. Super...
Dryer gets hot, outside vent seems to have plenty of air coming out. Lint screens all clean. But the unit takes two cycles to dry and in the past it always dried in one cycle. Whats wrong??
Is this happening on automatic dry cycle or timed drying?
It sounds like your moisture sensor is "confused" and shutting down heat prematurely.This part can be replaced.
Also double check your exhaust vent for blockages or standing water or sagging or open pipe
Also , your heater element may be shutting on or off prematurely. Could be a high limit thermostat problem. Or there is obstuction causing over heat
hope this helps
Aug 15, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Hello my dryer doesnt work properly it runs
The valve resistance is 1995 ohms and the ignitor is 185.
Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When the dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG dryer manual
Dec 13, 2010 | LG D2526 Gas Dryer
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Jul 14, 2010 | Samsung DV337 Electric Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
Jun 17, 2010 | LG DLG7188 Gas Dryer
Dryer will run for says then trip off, not the
If it is in timed dry mode, the problem is in the timer, if it is on sensor dry then you may have a clogged line. Easy to check, disconnect vent from back of machine and run it, if it dries without a problem then you need to replace or thoroughly clean venting. If it still does the same thing, check your thermostats, like the cycling thermostat, that is what advances the timer in sensor dry mode. What do you mean by tripping off? Do you replace the high limit fuse to get it to work again or does it just shut down?
Jun 15, 2009 | Dryers
My dryer used to shut off before the clothes are dry - now it wont start at all
Ok, the light will not come on if the door pressure swicth is damaged and, the dryer will not start if this switch is damaged as well. replace the door pressure switch asap.
Ok, concerning the interuppted drying cycle due to high heat, this can be cuased by two issue. It coudl be a venalation issue. if the dryers vent duct and exuast hoses are clogged, thsi will cuased the element to reach unsafe tempreturs, in return, tripping the high limit thermostsat and shutting the dryer off in the middle of the load cycle.
Another problme spot woul dbe a fualty high limit thermaostae. Although this is highly unlikey, this coudl be your issue.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jun 02, 2009 | GE DBSR453EBWW Electric Dryer
Slow to dry cloths
Remove the vent from the back of the dryer and see what the temps are. The cycling (or operating) thermostat is on the blower housing and opens more than 100* lower than the 266 you are reading. That, combined with the long dry times indicates an airflow issue. Check your lint screen....fabric sheet and lint can combine to coat and restrict air flow through it. Also check down in the blower housing with the lint screen removed. You'll see lint build up by looking down the slot with a flashlight. If it's restricted, so is the blower wheel and the blower housing. Also make sure the flap, or lovers at the vent hood outside are opening fully. Remove any accumilation of lint from there.
The high limit control is just that........If you cycling thermostat has failed, or does not open because there is no airflow, the limit control opens as a safety. On a normally operating dryer, the high limit control will never open.
The neptune dryer is designed to move more air than a regular dryer due to the higher capacity load it get's from the neptune washer. That is the case with most front load laundry pairs.
May 06, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Mar 05, 2009 | Kenmore Dryers
Whirlpool LEB6300 Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
