Main Draw (large Capacity) has a problem open and close front door if the code comes back then you probability have a broken gear in the 3 draw lift system. Usually the gear gets rounded out in the center. gear is black and located behind several gears behind the front cover of the draw
Error 990 is an error that has to do with the ink carridge system. This is a Ricoh defect. If your printer is still under warranty you can call Ricoh and inform them of the error and they should replace it. To try and fix is 50/50. We usually just recommend getting a replacement.
this is a problem caused by the gel that is not supplied anymore in the printer. certainly the waste ink collector behing the machine is full. by replacing it i solved the problem sometimes, sometimes it is more serious ans the sparepart of the supply must be replaced by crafted man. hope it can help !
