Question about Panasonic REGION FREE SCHT700 5 Disc DVD Home Theater PAL&NTSC System
Dvd home theater sound systen
No sound only one speaker works hooked up to direct tv reciever works fine when playing dvd
  • 4,234 Answers
Without seeing the machine and checking test points with a scope, all I can suggest at this point is that the switching chip is faulty. The DVD input will be routed through the surround sound processing section as well. Any problem with either the logic or switching can cause a symptom like this. This problem is not likely to be resolved remotely. See an auithorized Panasonic service center and invest in a detailed service estimate. Armed with that info, we should be able to guide you through the actual repair.
Dan
Posted on May 19, 2008
  • Panasonic Master
  • 13,433 Answers
Must be wired wrong. consult your manual on the connections, I'm not fimiliar with your model.
Posted on May 17, 2008
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
Xbox360 not hooking up to Curtis DVD5091 surround sound through optical cable
try running the optical cable from your dvd directly to your tv and then select whichever input (eg HDMI 1/2 etc) you use to play the xbox on..In theory this setup should allow any audio playing on the tv to go through the surround sound..hope it works
Feb 11, 2013 | Curtis DVD5091 Theater System
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
When I play a CD or DVD the sound plays normally, but when we try to watch TV the volume has to be adjusted to maximum and we can still barely here it.
thats correct man if your running sound from your tv to the reciever it is sharing the signal strenghth with the reciever and i will sound very weak the only way to correct that is to turn off your tv speakers and use your reciever as your primary sound source for the tv sound
Nov 12, 2009 | Panasonic SC-PT960 Theater System with...
CAN I PLAY THE DVD PLAYER WITH SOUND THROUGH MY TV WITHOUT HAVING THE SPEAKERS CONNECTED?
You can set up your tv in this way. Hook up your dvd player directly to your tv and then hook up your surround sound reciever from the audio out jacks from the back of your tv. This should allow you to use either your tv volume or the surround sound feature. Hope this helps
Oct 21, 2009 | Samsung HT-Q40 System
Where to plug in the home theater on the tv?
If you REALLY want to plug your tv into your home theater system there should be rca (red and white) jacks on the back of the tv that say "audio out" or "speaker out" thats your tv's audio output. which is where you would plug in the TV to your home theater system.
But there's really no reason to do this and its not the most desirable way to set u a home theater. Sound doesnt come from your tv, and therefore your tv shouldnt be plugged into speaker (unless you have old school wal cable) sound comes from your cable box, DVD player, VHS, Xbox, Ps3 etc. the sound comes from your source, and these sources should be hooked up directly you your home theater reciever
Oct 01, 2009 | Dynex Televison & Video
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
Can't get the surround sound to play the rear speakers and small front speaker
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Aug 04, 2008 | Panasonic Home Theater System System
Panasonic REGION FREE SCHT700 5 Disc DVD Home Theater PAL&NTSC System Logo
62 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
