posted by momawarbucks on May 17, 2008
When I connect to a projector, I get a no signal message. The Windows startup screen is visable but disappears and the "no signal" message appears.
I have tried the f7 function and it does not work.
Solution #1
posted on May 19, 2008
Hi momawarbucks
Check if your secondary screen is attached by going to desktop and right click , then go to properties and advanced.
Also check if your refresh rate is on 60-70 Hz
And that the resolution your PC is on , is supported by your Projector - i.e. XGA Projector - 1024x768
Good luck and thanks for using Fixya !
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Toshiba TLP S30 Multimedia Projector
Email this problem
Email this problem
Can you Help with these Multimedia Projectors problems?
Layer of Green on Screen
I got a new bulb for my... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
