Question about Acer Aspire One A150-1006 Notebook
Tried to do a BIOS flash. Comouter hung up so i had to disconnect to turn it off. Now it is dead! Even connecting the power wire does not light the little LED on the computer. Have I bricked it or can it be brought back. Nothing happens when i press power button.
    Guru:
  • 1,082 Answers
You have just bricked your computer. Good thing it wasn't super expensive.
If you are still in warranty, you might be able to get it fixed for free....
Posted on Sep 16, 2010
No sound and light on input selector knob is Flashing. Light only flashes when speaker switch has been turned to A, B or A&B.
This can happen if there's a dead short in a speaker wire or if you're using very low impedance loudspeakers at high volume for an extended length of time. If the protection light came on due to a speaker wire short, low impedance condition or a bad speaker, the receiver's power will need to be turned off to reset it. Before turning the power back on, all speaker wire connections should be checked for their integrity at the receiver side and at the speaker side. If the protection light goes on immediately after you turn on the receiver, disconnect the speaker wires at the receiver side and retest. If the receiver's protection light goes off, then there would still seem to be a problem with one channel's speaker wires or speakers. Connecting them one by one and retesting should allow you to find the problem speaker or connection.
Jan 14, 2015 | Audio Players & Recorders
No power to car key wont turn
check the alternator and check for a short or ground a wire may be touching the frame you may want to check the engine computer module
Feb 17, 2014 | 2004 Mercedes-Benz S 430
Black Scren of death
Turning off a computer during a bios flash is a horrible idea, and typically not done to a computer you should have planned on using again. Damage to a bios is irreparable, and unfortunately, requires the purchase of a new motherboard.
Sorry.
Dec 09, 2012 | Computers & Internet
My HP G60-230US Computer will not start. The computer is a little more than 2 years old. Every so often when I would start the computer it would say "No boot device found". I would restart the...
sounds like your motherboard malfunctioned. the board was probably starting to go out. thats why it would see the hdd then not.
you sound like youre familiar with computers. you may want to invest in diagnostic cards to troubleshoot problems like this. theyre fairly inexpensive on ebay. basically you insert the card into pci slot and it displays an error code. then you look up the code in a book. works like the obd2 reader for your car.
good luck
Feb 28, 2017 | HP G60-230US Notebook
Laptop does not start!!!! Hi, I have a problem that maybe you can help me with. I have a HP Pavilion tx-2510us, I turned it off and now it just refusses to start. I tried several different ways of...
yes, we have like 1000000000 posts here, LT does not start.
endless it is.... and few come backs, to show whats up.
its always the same reasons, short list.
Ok, not on time did you say the word BIOS>
did you know BIOS works with HDD/SSD removed
forget the OS for now,
if the BIOS ok called up the screen is ok
if not, then its a catastrophic failure.
you can even boot it with external, screens, 15pin pin VGA.
if not its DEAD if BIOS IS DEAD, that is a clear 100% dead
with battery out.,
so the power pack is bad.
ever consider that, i keep them as spares, so if on say vacation
mine blows out, i have a backup.
with a good power pack
the MOBO will work
and will beep if you remove RAM.
with special beeps, beeps are BIOS code running,...
if it cant beep the MOBO is toasted.
I uses a voltmeter on the rear of the power jack
19vdc is spec (the pack side tells you that in clear text)
ok its got power. (even with power button pushed)
ok power good, push power botton
and i must get beeps BIOS
one or the other, even with
here are the LED flash codes on my hp 8540.
hp.com has yours too, if you RTM ,read the service manual. for free
nice how fixya wrecks photos. sad
the blinks mean,
gpu dead
bios dead
cpu dead
ram dead
and more, this laptop dont beep it only blinks
so you must read the book to learn what YOURS does.
Mar 13, 2017 | HP Pavilion TX2510US Notebook
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
Gateway 503gr has no power, the standby light flashes green when I remove power. Tried new PS and the standby LED stays lit. I then tried both new and old PS disconnected from board and shorted...
Disconnect everything from the motherboard except the power supply connections and cpu fan. Install one stick of RAM and connect your monitor. Then try starting up. See if you get any BIOS boot messages. This will tell you that the board and processor are okay.
With what you say you've tried already, I'm thinking you might have a bad processor. Most every other problem would result in some kind of error like POST beep codes or messages on screen. If the system still doesn't boot with the bare minimum parts installed, replace the processor.
Mar 02, 2010 | Gateway 503GR PC Desktop
Power light Flashes on and off stays blue
Hi...there,
It's seems you got a busted AD Board... your LCD bios had been damaged or erased.
Dec 01, 2008 | Computers & Internet
My sansa player has hung and does not reset
Press the power off button, do not release, (20sec) wait until the screen blank. I suspect firmware bug, try to play around with increase timing on AutoShut-Off, example 10 mins, at the Setting.
Apr 13, 2007 | SanDisk Sansa e250 MP3 Player
Acer Aspire One A150-1006 Notebook Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
