Question about Sport & Outdoor - Others
I have a voit 507MS tredmill and the walking pad is ging to the right and rubbing against the wheel how do i fix it
  • 108 Answers
SOURCE: vibration in steering wheel and pulls to the right
Check your front brakes. You may need to grease the caliper slides and machine or turn the rotor. If the rotor is warped it will cause a vibration in the steering wheel, you'll notice it more under varying braking conditions. The caliper could be sticking which can cause a pull. As for the squeaky rear end, being a car that old its time to replace the rear bushings. If they are greaseable then just regrease them. If you replace them consider going with urethane or polyurethane bushings. They will give a better ride than the stock rubber bushings. If the new ones come with grease fittings make sure you grease them at least twice a year, but at every oil change would be wise.
Posted on Jul 15, 2009
  • 6 Answers
SOURCE: avid juicy sevens remain tight against disc
Juicy's are prone to sticky pistons.REMOVE pads,clean calliper ,pull lever lightly and add a drop of hydraulic fluid to the edges of the pistons to lube.Recess pistons,wipe off excess fluid and fit pads.If this doesn't work they might need bled.
Posted on Sep 26, 2009
capsman
  • 111 Answers
SOURCE: i took front wheel off bike to fix puncture. i
Loosen up the hub nuts. Center the wheel between brake pads. Put something like a screw driver in the space between wheel and frame to keep the wheel centered and not moving as you tighten the nuts.
Posted on Oct 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Neptune dryer tumbler rubs very noisily against
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Nov 13, 2009
bwinton
  • 83 Answers
SOURCE: belt slipping
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on Apr 30, 2010
The right treadle is rubbing against the right upright why
please see the video and proceed according for fix it.
Please remember to LUBE the deck belt+roller bearing too.
God bless you
Feb 27, 2013 | Bowflex Treadclimber
I hear a rubbing sound when i go down the road.when i slow up it stops,when i speed up it gets louder.it is coming from the front wheels i think.i just had the brakes done about a month ago???? help
Have the front wheel bearings checked they are a sealed unit that has to be pressed in or assembly removed and replaced. Or your brakes are dragging and rubbing against the rotor it could be the caliper is sticking or the rotor doesn't have enough wave, warp cut in it to push the pads back enough. Most people think a rotor is cut perfectly flat if this was true the pads would rub against the rotor all the time. The car could be jacked up and on stands and have someone listen for the noise right next to the wheel while you speed up the wheels and slow down with the brakes and don't try for 100mph you could hurt the tires
Nov 27, 2011 | 2000 Chrysler 300M
Replacement wheels for voit rowing machine
I have a Voit RM 4 rowing machine, and the 6 plastic wheels under the seat are dried up and broken. Any one know of a replacement option?
Oct 10, 2011 | Exercise & Fitness
Grinding noise from rear. Brake pads? Bearing maybe? Seems to be coming from the passenger side rear wheel area. Any help would be great. Thanks.
Have the rear brakes inspected. These are real easy to change if they need to be. You need to look under the car just outside the differential. This is an inboard brake system so the wheels don't need to be removed.
Feb 24, 2010 | 1986 Jaguar XJSC
I am getting a very loud rythmic grinding from rear end. I think its the wheel hub. Is this expensive? Can I change this myself?
both parts will be cheap from brake pads to wheel bearing if need to replace. 50 bucks for sets of brake pad and wheel bearing will be 27 bucks. rear grinding could be your brake pads are worned and rubbing against the rotor. you can do the work your self and don't need a shop as long you have the right tools. if its the wheel bearing than its going to be other task, which still can perform the work at home. Big 1/2 inch sockets sets with box and open end wrench will come in handy. if it the rear end it will be best to take it to professional to have the work done.
Oct 08, 2009 | Infiniti FX35 Cars & Trucks
I took front wheel off bike to fix puncture. i
Oct 02, 2009 | Cycling
Car is squealing persistently from rear right tire
Pull the wheel,you will find that the brake pad,or after pulling the drum,the shoes are in bad shpe,if not ,check the wheel bearing,but my bet is the shoes,or pads are bad,do A brake job,it will most likely be the problem.
Sep 25, 2009 | 1991 Honda Accord
Rummbling noise at rear wheels
Sounds like universal joints going out.
Aug 06, 2009 | 2003 Audi A4 Cabriolet
Right Rear Wheel is hard to turn, car has drag
you may have overtightened the retaining nut on the rotor holding the rotor on. try removing the wheel, remove the cotter pin and loosening the nut 1/4- 1/2 turn. when re-installing the wheel, recheck by spinning the tire. it should spin freely. over-tightening a wheel rotor can damage the bearing and cause it to overheat, even to the point of causing a fire.
Nov 26, 2008 | 1996 Ford Taurus
Sport & Outdoor - Others Logo
43 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
