Question about Garden
Where is the serial number located on the husqvarna 359 &353 chainsaws?
    President:
  • 2,220 Answers
On my 359 It is below item 2 (front handle) and is item 30 in the attachment.
Lou
Posted on Sep 16, 2010
Where to find vent line on 359 husqvarna
Husqvarna chainsaw fuel line check and replace - YouTube
? 3:44
https://www.youtube.com/watch?v=8FyU_fG9qwc
Feb 6, 2012 - Uploaded by mweba1
359. ... Husqvarna chainsaw fuel line check and replace. mweba1. SubscribeSubscribed .... You will want to inspect the tank vent and fuel line.
Husqvarna common air leak - YouTube
? 1:51
https://www.youtube.com/watch?v=Z7f9zNQTJBQ
Apr 11, 2012 - Uploaded by mweba1
Husqvarna common air leak ... Husqvarna 136 ChainsawCarburetor Rebuild & Fuel Line Repair - Duration: 22:39. by donyboy73 59,377 views.
Husqvarna 359 Professional Chain Saw Review
Dec 14, 2015 | Husqvarna Garden
357xp 359 After 15 to 30 min. of cutting engine gets extremly hot and cuts off. Checked spark plug,air filter, and made sure all cooling system components are cleaned. I was told it may be the...
The ignition coil is attached to the spark plug cable.Also check the spark plug number for the chain model.As the chain get older you can put a cooler spark plug and try before change the coil.
Nov 08, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
I need to know how to adjust the bar oiler on my husqvarna chainsaw
A link to an OM for a 2005 Husqvarna 357XP/359 follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1150046-95.pdf
The procedure is on page 35.
CAUTION: It only has 3 positions; forcing it beyond the stops may render it inoperative.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 13, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
What is the mix ratio for the Husqvarna 460 x-torq
I gallon of premium fuel to 2.6 ounces of quality 2-cycle oil is 50:1 and what Husqvarna says in the manual. You can download a current OM here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; black numbers on silver tag 90s; silver numbers on black tag 80s)
15 = week produced - March
00198 = 198th unit Husky produced that week
How do you like the your 460? I almost bought 1 myself (opted for 359). More questions or if you need more help please reply below. HTH
Lou
Feb 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
How do I reset the chain brake on my husqvarna chain saw
You can download an Operator's Manual and IPL for your 359 here:
HusqvarnaUSA.com
06 1500198
06 = year produced – 2006 (single digit before 2000)
On the IPL for the serial number used as an example (my 359), the eared part of 503 89 08-02 must be rotated Clock wise to open the chain brake. In the clutch cover it is the uppermost left component. Some say a crescent wrench works well. It may require some amount of force and a block of wood in the cover and a C-Clamp to a work surface may make it a little easier. Good Luck
Lou
Jan 09, 2010 | Garden
Husqvarna 340 oiler not working
Hello again Rudy.
Please reply below (Add Comments) with the serial number of your saw then I can investigate a little further.
You can reply even when the question is closed. I am not certain how but I get email notification of your reply when done correctly. If equipped the oiler adjustment is below the crankshaft on the clutch side. Look up from the bottom. On the side of my 359 is an icon of a link of chain with a drop of oil above it. The oiler adjustment is aft of that and can only be seen from the bottom of the saw. The manual I saw said 3 position only with CCW (3 - 18 to 20" bar) most oil. Forcing it beyond the stops causes a lot of problems.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2007/HOUS2007_1150331-95.pdf
Page 36
Is your serial number is between 07 18##### and 08 17#####?
Page 5 item 1 shows location of the serial number. Not all newer saws have an adjustable oiler. Please reply below.
Lou
Dec 18, 2009 | Husqvarna Garden
I have a used husqvarna 455 what size scrench do i need
You can find both an Operator's Manual and an Illustrated Parts List for your saw here:
HusqvarnaUSA.com
Serial number decode – for use with IPL
06 1500198
Take your saw with you and stop by a local saw shop (regardless of brand). Odds are good they have the correct scrench and it will cost the same without the shipping charges.
My 359 scrench is 13 & 19 mm. HTH
Lou
Nov 04, 2009 | Husqvarna Chain Saw 20" Bar
Chain oil leaks. repair shop. no need to repair. will start leaking again after few uses. is this true ? husqvarna 359
My 359 doesn't weep oil, one of very few that don't. But the oiler has never been turned above 3 or below 1.
Did you perhaps turn the oiler adjustment to far? It has only 3 positions. Check your manual.
Return it to the repair shop and make them stand by their work. If it stops when picked up from repair shop then starts again later something you are doing is the likely cause. Read your manual about oiler adjustment.
You can find both an Operator's Manual and an IPL here:
HusqvarnaUSA.com
06 1500198
GL
Lou
Oct 14, 2009 | Garden
353 husqvarna chainsaw, floods during start process
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually the next pull)
Warm:
  3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
  4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Oct 03, 2009 | Husqvarna Garden
Bar oil leaks when saw not in use
What you describe is common in many chainsaws. Try loosening then reseating the oil cap before putting her away to relieve any pressure built up in the oil tank. Check all the hose connections.
HusqvarnaUSA.com
Enter the 3 digit model number of you saw; uncheck "Manuals"; Check “Illustrated parts lists ”; then search.
Serial number breakdown: 06 1500198 (Husqvarna 359)
06 = year produced (prior to 2000 there is no space and only the first digit is used (61500198 could be 86 or 96))
15 = week in 2006 it was produced (March)
00198 = 198th unit produced that week regardless of model or type
Sep 24, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
442 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
