Question about Muratec Office Equipment & Supplies
Hello. I have over 300 numbers programed and we recently moved and now we have to dial "9" before the number. Is there a way I can pre-program the fax to plug a "9" before dialing?
    Genius:
  • 1,218 Answers
If the machine is one ofthe newer variety where it is connected to the PC ...then you can alter your "Auto-Dialer" from your PC.
If it is not a PC connected machine then you will have to go in manually and change the programming on each individual number.
Posted on Sep 17, 2010
Hi I have a panasonic KX-T433 phone system which I am trying to put in speed dial numbers, we have to dial 9 to dial out does any one know how to do this using a 9 in front?
You have neither a 7730 (the category you asked in) or a 7433 phone sytem. If your phone is really a 7433, you have a TD phone system. Which "speed dial numbers" are you trying to program? System speed dials, are stored in system program 001 and consist of a 3 digit number (may be 2) with a "9" in front and the number as you would dial it from the keypad. Personal speed dial numbers depend on the button you're programming it onto. If it's a button with a light, you dial "2" in front of it. If not, you don't. So, Program 99, button, and either 29 + number STORE or 9+number STORE programs a personal speed dial.
There are other programs to store under the tone pad keys. Those features are covered in your User's manual for the TD system.
Carl
Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
Forumla for adding speed dial numbers
Personal speed (the 12 F buttons on the right) depend on whether you dial "9" to get an outside line. Then the buttons are programmed by pressing PROGRAM the button and dialint the speed dial number with a 9+ then STORE. System speed dial number sare programmed in SYSTEM programming 001 and they have "9" also in front of them.
Carl
Jun 18, 2011 | Panasonic KX-T7730 Corded Phone
Hello, please i want to know how to set up speed dial on the KXT7730 that is not the main line ie not on 0, or 101 on the switch board
Guessing that you already know about SYSTEM speed dials, then the 12 buttons on the right side of your phone are the PERSONAL speed dials. When you get dial tone on the intercom, you can dial "9" and the system will either give you a dial tone, or the highest line in the system. If that is not a working line, you need to fix that first (system program 400 assigns lines in service).
Once you have that, a PF button is programmed by pressing PROGRAM, the button, and dial 9 + your number dialed the same way as if you had pressed a CO button then STORE. You can keep pressing PF buttons and programming numbers. Then press PROGRAM or pick up the handset and drop it back down to end programming.
Carl
Apr 21, 2011 | Panasonic KX-T7730 Corded Phone
How do I store a number for autodial at a later date?
Autodial? You're going to use one of the 8 buttons for autodial or are you trying to put system speed dialing in? The phone buttons are easy if you dial "9" to get an outside line. You press PROGRAM a button, and dial 29 plus your number and STORE.
Now, obscurely, you can program one of the 8 buttons to SAVE a number. Thats done by PROGRAM the button 5 STORE. When you dial a number that you want to save, you press Autodial and SAVE (the button you programmed) and it will save that number under the button.
Now, grab a line and press the SAVE button and it will dial your saved number.
Last, if you're not totally bored, you can store 10 Personal speed dial numbers on your phone. They program by 2* (0-9) number # and are dialed by pressing # (0-9).
Yeah. BTW this is an instruction set for a TA-624, common for the type of phone you have. I think it applies to most of the TA series KSU's.
Carl
Mar 25, 2011 | Panasonic KX-T7560 1-Line Corded Phone
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
Sep 14, 2009 | Panasonic KX-T7730 Corded Phone
Programming Auto Dial Number
Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
Number changed :-)
You can keep putting in a whole boatload of new numbers with this procedure.
Carl
Mar 16, 2009 | Panasonic KX-T7633 Corded Phone
Programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Pre-set dial numbers
Pick up the handset / handsfree button, hit the SET/SAVE key, punch in the entire phone number you wish to program to speed-dial, hit the SET/SAVE key again, hit the speed dial key you want to save to (0-9). To actually use the speed-dial key once set, you have to pick up the handset / handsfree, hit the AC key followed by your speed dial (0-9) I know this seems unusual and you have to do it relatively quick, but it's the only way that works properly on this phone unit. Cheers!
Mar 31, 2007 | Innovage 69420210126 Phone
61 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
