Question about Emerson (025806803716) Wine Cooler
I have had an Emerson wine cooler Model# FR23RD for a couple of years and the unit will no longer maintain a cool temperature. What can I do to trouble shoot the problem and possible repair?
5 Suggested Answers
  • 3 Answers
SOURCE: Emerson wine cooler /ER2352
I had a similar problem and just solved it.
My cooler was leaking and had trouble keeping the proper temperature.
It was also making a buzzing sound which is what lead me to my solution.
BTW - The liquid that was leaking was condensation, probably because the unit was not holding a constant temperature.
Unplug the unit first - no need to get electrocuted.
These units use peltier cooling- essentially a large heat sink with three fans attached.
Click here for more info regarding peltier cooling.
The peltier unit is not repairable, but the fans are; which was what my problem was.
There are three fans on this unit, one on the inside and two on the outside.
Follow these steps to remove them.
  1. Remove the rear cover. It is held on with ten screws. This exposes the two exterior fans and the peltier heat sink
  2. The heat sink is held on with four screws - remove them and pull the heat sink out. The third fan is on a short wire lead, so be careful when removing the heat sink from the body of the cooler.
  3. The two exterior fans are connected to a control panel, the electrical connection is easy to disconnect.
  4. Once all of the wires have been disconnected, you can remove the fans from the heat sink.
  5. The fans are screwed to a mounting plate, which is screwed to the heat sink
  6. You must remove the mounting plate first to expose the screws that hold the fan to the mounting plate. The fans are typical computer case cooling fans
  7. I only needed one fan, but replaced all three because I didn't want to do this job again.
  8. I purchased my fans from Newark.com the prices were better than what I found at the computer websites. Also, these fans are much better than the original and will hopefully last much longer than the three I got from the old ones.
  9. You need one of these and two of these. The total with shipping was around $30
  10. You will need to splice the old electrical connection sockets onto the new fans using wire crimpers or solder them on.
  11. Attach the components in reverse order and power on the unit.
  12. These fnas may move more air than the originals, because the unit seemed to cool much quicker than I remember.
  13. Total time for repair is about 45 minutes
Hope this helps and Good Luck
Posted on Jan 16, 2009
  • 3 Answers
SOURCE: Emerson FR24RD Wine Cooler
If you are handy with small electrics, or know someone who is...
localwonder
  • 6784 Answers
SOURCE: Need user manual for Emerson Wine Cooler FR23RD
HI. i couldn't find the FR23RD but, i have been told that this manual covers your model. It basically covers FR24SL threw FR24RD. Your model is also covered in this edition. Click to review your manual.
Please rate and god bless.
Posted on Mar 22, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Electricity works, unit doesn't cool.
Hi and welcome to FixYa. I am Kelly.
This is a 6 or 8 bottle free-standing wine cooler from what I can tell.
I am not having much luck determining if this is a manual defrost type unit or not. Given the inital sales price now of $79.95 I have to assume it is a manual defrost type.
There are a few things that can cause your problem.
1. PTC relay and KliXon thermal overload assy on the compressor.
2. Run capacitor
3. Temp control
You said the fan does not run so I cab not rule out the temp control.
I can not even find a parts break down of the unit.
With no fan running the very first suspect is the temp control but you can at least listen for a CLICK when you cycle it from off to any other position. If you hear a click I would start looking at compressor start / run parts.
If you have access to your units compressor note the manufacturer, hp if stated (1/8hp etc) and Model number.
Then call or visit your local appliance parts supply store with that information in hand. The will have a PTC relay / KilXon thermal overload AND run capacitor that will fit your unit. I am pretty sure that will get you going again UNLESS you have a broken wire somewhere.
The replacement parts are going to run about 50% of the cost to replace the whole thing.
Thanks for using FixYa!
Kelly
Posted on Feb 19, 2010
Wine cooler cools but has a very loud, too loud to ignore, whirring sound when it is in cooling mode. Any ideas?
And when the wine is cooled ... the noise stops?
It's like a refrigerator ... it only operates when it it is reducing temperatures. Once things have cooled, the system cuts out.
If your wine cooler stops making a noise when the wine is cooled ..ok.
Jan 19, 2016 | Refrigerators
I need to lower the temperature
There is a thermostat that is seen on the unit , you will have to set the thermostat to a lower level. Also check if there is any gasket leak to confirm that the cooling does not stay.
Keep the cooler away from hot spots to encourage the cooling to stay.
Sep 17, 2010 | Emerson (025806803716) Wine Cooler
2. Run capacitor
3. Temp control
Kelly
Feb 19, 2010 | Emerson (025806803716) Wine Cooler
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
Mar 22, 2009 | Emerson Refrigerators
My Emerson Model FR23RD is not working due to a power outage and I do not remember the cost of it a year ago, can anyone help?
I have seen this unit on sale for 79.99 @ Target many times over the last year or so.
In fact, it's that price there now and also at Amazon.com.
The highest price that I recall seeing was probably 99.99
Jan 05, 2009 | Emerson (025806803716) Wine Cooler
Nov 26, 2008 | Emerson (025806803716) Wine Cooler
Aug 03, 2008 | Emerson (025806803716) Wine Cooler
VP500 Cooling unit issues
http://www.rosehillwinecellars.com/3rsV2/54_RHWC_plans/tuscany_plus_250_500.pdf
above is a link to the Vintage Keeper manual PDF format manual and problems and trouble shooting guide
Oct 23, 2007 | Vintage Keeper VP500 Wine Cooler
Emerson (025806803716) Wine Cooler Logo
Top Emerson Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Emerson Furniture Expert? Answer questions, earn points and help others
