Question about HP ScanJet 4600 Flatbed Scanner
Can anyone tell me where to buy the data/power cable for scanjet 4600
Part Number is Q3110-60009. Prices vary depending on vendor. Does not include AC Adapter.
Posted on Nov 08, 2010
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    h20564.www2.hp.com/hpsc/doc/public/display?...na...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ...
    h30434.www3.hp.com > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
Pin out for HP Q3110-60009
This is a simple cable, connector for 2 pin power supply, connector for USB 2.0, and male six pin round cable (same as PS/2 Keyboard/Mouse.) I have the scanner and power supply.
tia
Mar 30, 2012 | HP ScanJet 4600 Flatbed Scanner
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
No OS 10.5 driver for hp 4600 scanjet
Hi ,
Kindly Copy the below Link to an Browser for Downloading the Mac Driver.(Copy & Paste).
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=297431&prodTypeId=15179&prodSeriesId=297429&swLang=8&taskId=135&swEnvOID=219
May 23, 2009 | HP ScanJet 4670 Flatbed Scanner
Scanner stopped in the middle of a scan
Although I can not be sure without testing it, the most common problem with this type of issue is that the power supply adapter has failed. According to the manual (posted at http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00215714/c00215714.pdf) this scanner has an external power adapter. Since you indicate that the scanners light does not come on, I would be inclined to believe that power adapter needs to be replaced. However, before you go and buy a new one, I would suggest you get the current adapter tested with a volt meter to determine if it is outputting the correct voltage and amperage.
If you discover that the power adapter has failed, you may be able to simply replace it in order to get the scanner up and running again. However please take note that depending on what part of the adapter circuit failed, its failure could possible have also damaged the scanner's internal circuits. However, if you find after testing that the adapter is outputting the correct voltage and amperage, then the problem would most likely be a scanner board circuitry failure.
May 04, 2009 | HP ScanJet 4600 Flatbed Scanner
HP Scanjet 4600 problem
that means your scanner has a problem internally. bring it to the nearest service center or buy a new one coz its much practical than paying a service fee more than the cost of a new one.
Jan 14, 2007 | HP ScanJet 4600 (refurbished) Flatbed...
HP ScanJet 4600 Flatbed Scanner Logo
133 people viewed this question
Seeker5211
Seeker5211
