Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Intercom Does the Intercom have an auto answer option?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
What model Uniden DECT 6.0 phone?
Posted on Nov 26, 2013
Automatic Intercom
Hi Raegan
in themiddle of the handset will be a button which is lit this button will say auto answer mute around it. Press this button will stop the problem.
Speak Soon
Phil
Nov 14, 2012 | Panasonic KX-T7633 Corded Phone
Nbx auto answer
At Two scenarios it will be happening.
1. When your phones act as a intercom.
2. When your server settings are enabled with auto-answer option.
Check with server admin.
-Karthik.
Sep 27, 2012 | 3Com NBX 3101
Panasonic KX-NT136 - how do you page directly to another extension and begin talking to the other person without them picking up?
It's not called page, it's INTERCOM. On the face of most Panasonic phones, there's a button labeled AUTO ANS. When you press it, it lights up. If the options are set properly, it becomes the Voice Announce/Auto Answer button. Every phone you want to have the VA feature on has to have that button lit. When you call them on the intercom, it will beep twice and your voice will be on the set and they may or may not be able to answer back handsfree.
It requires system programming and theere's a code you can dial to block it.
Carl
Mar 23, 2011 | Panasonic KX-NT136-B Hybrid IP Telephone -...
Why does the auto dial/store button lights up by itself on the kx-t7730
Get a picture of that and send it to Panasonic! Your phone would be the *ONLY* one that does, since the button has no light.
Now, the AUTO ANS/MUTE button lights up when pressed to put the intercom in the Auto Answer mode under certain conditions. That could be the one you're seeing. It either forces intercom calls into auto answer if it's a ringing call, or into handsfree answerback if it's a voice call. It also indicates a muted microphone on speakerphone calls.
Carl
Aug 17, 2010 | Panasonic KX-T7730 Corded Phone
KX-T7730 Corded Phone: WHEN THERE IS AN INTERNAL INTERCOM ACTIVATED TO AN...
Make sure the Auto Answer button is not lit on the empty desk phone, then you could use either 40 to answer all calls, or 4+ the extension number to absolutely answer that phone.
May 06, 2010 | Panasonic KX-T7730 Corded Phone
We use an RCA 25415 in our office and can not get the intercom to work, any suggestions?
http://www.rca4business.com/products/pc/pdf/instruction-book/25415RE3.pdf
If you click on the above that is your manual.
go to page 10 for Intercom auto answer.
and page 19 for Intercom calls .
Hope it helps!
Jan 12, 2010 | RCA 25415RE3 Phone
Intercom use
We have the 25414RE, so I can tell you how ours works and hope it helps solve your problem...
You first have to assign each phone a "number". Push the menu button, and go to phone options (you scroll by pushing the review button to the left or right), choose set phone id (once you are on that option push the select/save button just above the review button) - I started with the first phone I plugged in and made it number one, and so on (we have a total of 5). Once the phone ids are established, simply push the intercom button and the corresponding number on the right speed dial/intercom numbers - it should dial the phone you want. It also has an option (again we have the 25414RE) to have the phone auto answer the intercom - so if you are paging someone in a room that isn't near the phone, or the phone is shared by several users, it picks up without anyone having to push anything. Otherwise, the phone that you are calling has to either have the handset picked up or the speaker button pushed. Hope that helps you!!
Mar 10, 2009 | RCA 25404RE3 Corded Phone
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Re: Question
    Your phone can have 3 options, Ring all the time, Switch between Voice and Ring, or Voice all the time.
    From your phone(s) press PROG 21 and press the ENTER soft key (3rd key). Now press the SEL (3rd key) until it says VOICE CALL then press ENTER and EXIT. If you set it to this mode, the AUTO ANS button won't work.
    If you select TONE, the Auto Answe button will work, making the phone VOICE CALL when lit and ring when not.
    If you select VOICE CALL DENY, the AUTO ANS button still won't work and ...you get the pattern.
    Carl
    Oct 22, 2008 | Panasonic KX-T7633 Corded Phone
    Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
    60 people viewed this question
    Top Uniden Lands Phones Experts
    Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
