Question about Maytag MLG23PD Gas Commercial Dryer
Maytag mlg23 has no lights on display board - Maytag MLG23PD Gas Commercial Dryer
Have a samsung refrigerator model rb1955sw will not turn on no lights, fan, or compressor just FD in the front display
I think you might need to replace it and if you still have a reciet that could be usful or they might fix it just call up the store
Mar 25, 2014 | Maytag MFI2568AES Stainless Steel Bottom...
All display lights blink
You will need to replace the main board on the back of the unit. Here is the board to order. Be sure to program the board when you install it. There will be instructions that come with the board.
The part comes with a 365 day, any part, any reason return policy.
Nov 20, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Lcd display is dead - oven heats up and oven light work
The display could have a bad connection on the board or just have failed. Either way you are looking at replacing the complete board assembly. Eric
Aug 18, 2010 | Maytag Ovens
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
My maytag mfi2658aes and my ice and water not
Your display board has gone out on your dispensor. This is a simpe repair and we have parts for Maytag appliances.
Just give us a call with your brand andmodel number and we will be happy to get the correct part out to you asap.
We hope this solves your problem and we look forward to working with you.
Nov 03, 2009 | Maytag MFI2568AE Side by Side French Door...
Oven and oven display do not work or light up, but stove top and over light still works
Check if there both hot wires and the neutral are ok at the control board.
You should have 110-120v between each hot wire and neutral, and 220-240v between two hot wires. If power is ok, replace control board (the display unit is on the control board).
Part numbers:
White: 74009221
Black: 74009223
Bisque: 74009222
Repairclinic.com has pictures of the parts.
Oct 14, 2009 | Maytag MER5775Q Electric Kitchen Range
We have a french door botom freezer maytag w/ and electronic water/ice dispenser. Model #mfi2568ae In the middle of the night the ice dispenser started opening and closing by itself and the led display is...
Don't be duped into thinking the display/dispenser board is the culprit. It may come a surprise, but this failure is often misdiagnosed. Because the dispenser is causing such a ruckus or because the display itself is blank or flickering, folks are led to believe that the display control board itself is the part that has failed. Looking at the history of our board evaluations, this little tiny control board rarely fails. And as crazy as it may seem, it is the main control board, aka the high voltage control of the fridge that is causing your refrigerator not to cool and the dispenser to be erratic.... This is the main control board of the refrigerator, located on the back of the unit. I've attached photos of what this main control board looks like. This main control board will need to be repaired to replaced.
http://blog.fixyourboard.com/2016/06/08/ice-dispenser-flapping-display-flashing-on-refrigerator/
Ice Dispenser Flapping and Display Flashing on Refrigerator
Aug 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag MLG23PD Gas Commercial Dryer Logo
46 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
