Question about Fujitsu ScanSnap S510
When trying to scan to email I get an error message that indicates: "Sending Email failed or Send operation was canceled (0 x 0003). I tried sending an email yesterday that has not been delivered yet.
2 Suggested Answers
SOURCE: Sending E-Mail Failed (0x80004005) - Fujitsu ScanSnap S510
You need to open Internet Explorer and add Thunderbird as your email program. Click Tools > Internet Options > Programs tab > E-mail: Select Mozilla Thunderbird from the drop down.
Posted on Feb 07, 2011
Can recieve but cant send
Unable to Send Email? Check These 5 Things - rackAID
https://www.rackaid.com/.../cannot-send-email-how-to-fix-email-sending...
This likely means SMTP authentication is not enabled. If you get a relay denied error and your password is correct, then SMTP authentications is likely not correct. Often, email users with this issue can receive but cannot send email.
I am receiving email fine, but I cannot send messages ...
www.gn.apc.org/.../i-am-rec...
Association for Progressive CommunicationsThe usual symptom is that Thunderbird will try to send for about 20 seconds before giving up with "Sending of message failed. The message could not be sent ...
Are you able to receive emails but not send? - Hostgator.com
support.hostgator.com > ... > Email > Email Troubleshooting
If you aren't able to send email, this usually means one thing: your internet provider is blocking you from using anyone's outgoing mail servers but their own. ... so that theycan monitor outgoing email on their network in order to prevent spam.
Problems Sending Mail - Receiving is Fine - InMotion Hosting
www.inmotionhosting.com > ... > Email > Email Troubleshooting
Jan 14, 2015 - Outlook 2013, cannot send mail, but can receive mail ... I haven'treceive any mail since yesterday and I can't send mails too... can you help me ...
I can receive emails but i can't send them. ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple
Jan 20, 2016 | Le Pan II 9.7" Tablet PC
Fines not sending to email
try to scan it one by one as your scanner and processor is somewhat slow or defecxtive
May 17, 2013 | Canon imageRUNNER 3225 Black and White...
Cannot connect to subscriber in China
Typically this error indicates that you are trying to send your Adhost email through Adhost’s mail server when you have not authenticated your email account to send mail. Our mail server authenticates you through your pop account. So when you check your email, our mail server authenticates your pop user and password, captures that IP that you are checking your email from, and adds that IP to our relay list. This list is flushed every 70 minutes. This means, if you try to send email after the relay list has been flushed and before you’ve attempted to check your email, you will receive this error.
How to fix the problem:
Fix #1 - reauthenticate on our server.
Remove any email from your Outbox. If you need to keep the message, you can move it to your 'Drafts' folder.
Click "Send/Receive". This will reauthenticate you.
Try resending the email.
Fix #2 - configure your email client to check for email before sending.
In Outlook, go to "Tools" and select "Email Accounts". Make sure "View or change existing e-mail accounts" is checked. Click Next.
Select your account from the list and click "Change".
Select "More Settings".
Select "Outgoing Server".
Check "My outgoing server (SMTP) requires authentication".
Select "Log on to incoming mail server before sending mail".
Click "OK", then "Next", then "Finish".
This will fix your problem
Or
Call Yahoo! Customer Service
USA: 1-866-562-7219 --- 1-800-318-0631
UK 020 7131 1000
Canada: 1-877-722 3755
Direct Number: 1-408-349-1572
Regards
manish
Mar 20, 2010 | Yahoo Mail
Getting error code for sending e mails from Windows Vista home. Ox8OOCCCOD
Third Party Solution Found: From Microsoft
Error 0x800CCC0D
Problem: When you try to send or receive email, you get an error message. It
says the error number is 0x800ccc0D.
Solution: This error is basically saying that your computer cannot connect
to the mail server. The most common and obvious cause of this is that you
are not connected to the internet at all. To test whether this is the case,
try opening a news web page like news.com or doing a Google search (just
opening your homepage is not a good enough test, because it may be saved, or
"cached", on your computer's hard drive). If this test fails, then the
problem is not with e-mail specifically, but rather with the internet
connection. For users on dial-up, you need to dial in first, and then you
should be able to check your email. If Windows is indicating that you are
already connected, try disconnecting and then dial in again. If that fails,
try restarting the computer and then connecting again. If that fails, you
may have spyware or your modem may have gone bad.
If, on the other hand, you are able to pull up web pages, yet still get
error 0x800CCC0D, you should check to make sure the mail servers are typed
in correctly. To check this in Outlook Express, open the Tools menu, select
Accounts, click on the Mail tab, click on the Properties button, then click
on the Servers tab. Or, if you use a different email program, follow the
equivalent procedure for that program. The incoming mail server should be
pop3.vcn.com unless your email address doesn't end with @vcn.com, in which
case put in whatever your address ends with instead of vcn.com (for example,
if your address is person@wavecom.net, enter in pop3.wavecom.net ). The
outgoing mail server should be smtp.vcn.com or substitute whatever your
email address ends with for vcn.com.
Make sure to check the mail servers for all your mail accounts if you have
multiple email addresses.
If you still get error 0x800CCC0D, and definitely can pull up web pages
(that is, the rest of the internet is working fine, only email is having a
problem):
* Restart your computer. This is simple, so you might as well try.
* Try disabling e-mail scanning in your anti-virus program. To do this
in Norton, double-click on the yellow picture for Norton down at the bottom
of your screen by your clock to open Norton. Then click the Options button
at the top of the window (if a drop-down menu appears, choose anti-virus),
then click the word Email on the menu on the left side. Uncheck both Scan
Incoming and Scan Outgoing. Click OK, then close Norton. Try checking your
messages again.
* Disable your firewall. It could be blocking Outlook Express, or
whatever your email program is, from accessing the internet. McAfee firewall
will usually not turn off even when you tell it to, so you'll have to go
into the firewall settings and delete your e-mail program from the blocked
list, or just uninstall McAfee firewall entirely using the Add/Remove
Programs control panel.
* Make sure you recieve replies when you ping the mail server. If you
cannot, something strange is going on.
* Try checking email using a different mail program such as Thunderbird,
or through webmail on our web site, and see if that works.
Other Cases
You may be able to get mail when you first open Outlook Express, but then
get error 0x800CCC0D from then on. To solve this, go to the Tools Menu >
Options > Connection tab, and uncheck "Hang up after sending and receiving".
Your email works fine, but error 0x800CCC0D keeps constantly popping up over
and over. In Microsoft Outlook, Tools > Options > Mail Setup tab > Send and
Receive, and uncheck "Schedule an automatic send/receive every 5 minutes"
(older versions of Outlook will have a similar option under the Mail
Delivery tab). In Outlook Express, go to Tools > Options, and uncheck "check
for messages every ... minutes".
Shenan Stanley
MS-MVP
Quoted and pasted by Jack Isaacs for FixYa
Hope This Helps.
Jack Isaacs
Jan 29, 2010 | Microsoft Windows XP Home Edition
Jul 19, 2009 | Fujitsu ScanSnap Manager
How do i unsend a eamil i sent and then deleted it
HI,
if you are trying to send an email and don't want to continue as fast as you can do cancel it by looking in the "Outbox folder"
if you already send it and message appears succesfully sorry to say but we cant do anything about it to stop sending.
you can check all succesfully email send in your send items.
any further question let me know.
thanks,
Mar 21, 2009 | Computers & Internet
Problems with sending and receiving emails
This particular account is trying to relay. Having worked for an ISP before most people do not allow this. Have you EVER been able to send to this person from this same account that you are using?? Chance are no and the reason you can send to someone else is because there account is fine. Can you send an email to yourself or another email that you may have?
Dec 01, 2008 | Yahoo Mail
Sending error
I had this same issue and found your question. Well I figured it out. Go into either the web interface or the menu system and set SMTP/POP to OFF. The e-mail will error out within 10 minutes. Then turn the SMTP/POP feature back on.
In the web interface,
Network Settings
POP3/SMTP
Tick POP3/SMTP to OFF
Let the send error out within 10 minutes.
Tick POP3/SMTP back to ON.
Solved!
Jul 14, 2008 | Brother MFC-8840D All-In-One Laser Printer
Ricoh Aficio 1075 - SMTP error message
To use the scan to email function on your copier you need some settings from your internet provider (email setting specifically). Go into Outlook options and get your SMTP server, user name and password.
On your copier you need to change under User tools, system setting and file transfer and put these settings in. As long as your machine is set up for scan to folder thats all you should need.
Apr 18, 2008 | Ricoh Aficio 1013F Copier
Faxing/scanning from AIO 964
throw it in the dumpster and buy a new one
Mar 03, 2008 | Dell Photo 964 All-In-One InkJet Printer
Fujitsu ScanSnap S510 Logo
633 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
