Question about Whirlpool Kitchen Ranges
I have a old whlipool range. The control panel says F2 E1. I cannot fix the panel to the clock or bake etc etc. However the burners come on and it keeps beeping. I had to unplug the stove. What can I do?
  • Whirlpool Master
  • 1,711 Answers
F2 - E1 Keypad cable unplugged 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Posted on Oct 04, 2010
Hotpoint propane model rgb746hed2wh oven burner will not turn off, Digital reading f-2
F2
During BAKE, Control senses oven temperature above 615F-630F
f actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC). Here is the part to order.
Dec 16, 2013 | Hotpoint RGB745 Gas Kitchen Range
Error f2:e1
F2-E1 - Touch Pad (Keypad) Cable Unplugged - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 15, 2010 | KitchenAid KESC307 Electric Kitchen Range
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
F2 E1 - Cancel key invalid on Kitchenaid range
F2 E1 Cancel key. Cancel key invalid. Needs surface cleaning.
this is what the tech sheet says. But I am sure you did this. This type of failure looks to me that the glass control user interface needs replace. There is a 5% chance that is the control board. But very unlikely. let me know if you need help. Part 9754350CB
Part 9754350CB
part number 9754350CB
appox $230.00
Apr 27, 2010 | Kitchen Ranges
E1 F5 sign on panel control
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%^&*
Apr 20, 2010 | Whirlpool GR399LXHS Electric Kitchen Range
My GE profile gas range jgbp79wewiww the clock blinks f-2 and i have to light the burners with a match tks for any help
Hi There
I have found the code for and hope this helps you.let me know how it goes.
F2 During Bake Control senses oven temp above 590 degrees F High resistance connection in oven temperature sensor circuit. Check Electronic Range Control (ERC) - Welded bake relay contactsThank you for writing to fix ya.
Best Regards Richard
Mar 20, 2010 | GE Profile JGBP79 Gas Kitchen Range
Whirlpool accu bake oven door locked after self cleaning
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^YRG
Apr 21, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Hotpoint stove with f3 code.
Replace the oven control module.It controls the bake and broil including clock and timer functions.
Jan 28, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Kitchen Ranges Logo
193 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
