HT Tripping? Switches on then almost immediately goes into standby (HT tripping?).
  • 8,617 Answers
I will need to know the model number of your set to even begin to make a suggestion as to the possible cause of it shutting down. please post the model number
Posted on May 17, 2008
What is the problem of lP and HP compressor trip immediately after start the machine?
Make sure your ground wire the green wire is not loose and make sure none of your wire are not grounding out tripping the reset button near or around the motor...Make sure your ground wire the green wire is not loose and make sure none of your wire are not grounding out tripping the reset button near or around the motor...
Jun 01, 2016 | Air Tools & Compressors
Dishwasher is tripping RCD, can it be repaired?
not necessary-- yet-- to buy a new unit
tripping the rcd is an indication of earth leakage which could amount to water in the wall plug across pins, moisture across the power board, water in the motor, faulty heater element
what you need is an accredited electrician to run tests on the system to find the reason for the earth leakage that is tripping the rcd
the rcd works from microvolts and operates in nano seconds to prevent electrocution of the operator
testing before buying may save heaps of cash
May 19, 2015 | Stoves Dishwashers
99 Gr Am Pontiac AC
Have you checked the high and low pressure switches ?
Aug 25, 2014 | 1999 Pontiac Grand Am GT
How to stop my whirlpool washer from tripping gfi
If it is tripping the GFI I would say you have created a short somewhere. Check that wire has not been braised, check the plug for signs of burning, check outlet for signs of burning. Plug another device into the outlet to see if something else trips the GFI. If something else trips it then you could have a bad GFI outlet. These are the basics to try first but could be a number of things beyond this.
Aug 31, 2012 | Whirlpool Washing Machines
Trips and switches off
Hello Fixya customer,
Thank you for your question.
The best way to fully isolate the fault is to disconnect all the speaker wires, and verify that there are no strands of wire shorting between the speaker terminals on the rear of the unit.
Turn the volume all the way down, full CCW, and if it goes into shut down with the STBY light blinking then there is a fault in one of the amplifier's.
Thank you for using Fixya, and if I can be of further assistance please ask.
May 01, 2010 | Onkyo TX-SR706 Receiver
2 way light switch tripping breaker
connected wrongly on one switch or neurtal wire is present at one box is shortening,thus tripping
Oct 05, 2009 | Gardner Bender #GSW-SK Door Switch
Tripping of circuit breaker
Check what other appliances are on your circuit. What goes off when the breaker is tripped. You may need to relocate the microwave to a different circuit. Try to stay away from the refrigerator or AC circuits.
Nov 03, 2007 | GE JVM1440 Microwave Oven
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
