Question about Uniden BC60XLT-1 Handheld Scanner
Is my scanner suppose to stop scanning when i charge it
    President:
  • 2,761 Answers
No - when your scanner is being charged it should operate as normal.
Bill B.
Listening in since the 60's
Posted on Dec 16, 2010
What does it mean when a channel is "locked out"?
That is a setting that is used for channels that are constantly broadcasting but you don't want to scan them because they will stop the scanner. An example is the noaa weather channel. You may want to have it on the scanner as a channel but you don't want to scan it because the scanner will stop on it all the time.
Feb 25, 2015 | Uniden Bearcat 560xlt 560 Xlt 16ch Police...
Will not scan properly
Hello
I suppose you are trying to scan the channels by hand, If I'm not mistaken this model can also be hooked up to the pc.
Manual pages 55 and forward are on scanning, I suppose you have been throught those.
I't must be a simple setting wrong somewhere.
May 15, 2008 | Radio Shack Pro-2052 Scanner
Can someone tell me why my scanner won't scan? It is supposed to scan when you turn it on, it doesn't do that either. Any help would be apreciated. Thanks.
You may have to press a button to make it scan but also there may be no channels programmed and if so there is nothing to be scanned.
Nov 05, 2013 | Uniden BC60XLT-1 Handheld Scanner
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
My ls4278 is not lighting up when on the cradle, will not scan or charge...i have 3 scanners and cradles and somehow all the scanners stopped working completely..all the cradles have the light on but when...
The most unlikely scenario is that all the bases are defective. If you power your PC off every night, you should purchase a power supply so the scanners can continuously charge. Another issue may be that you need new batteries (also unlikely if they stopped working at the same time). Also try swapping scanners and bases (one scanner from one base and place it with another base) make sure you firmly place the bottom of the scanner in the base to verify there is a good connection with the charging pins. We are here to help if you have further questions.
Tech Support Barcoding Technical Support
May 18, 2011 | Symbol LS 4278 Barcode Scanner
We have an epson stylus SX410/TX410 printer, copier and supposedly a scanner. However, we cannot see how you scan to a computer and cannot see the scan button. Advise please
I have an epson stylus SX410/TX410 printer, copier and supposedly a scanner. However, we cannot see how you scan to a computer and cannot see the scan button. Advise please
Aug 25, 2010 | Epson Stylus Multifunction Inkjet Printer/...
HOW DO I PROGRAM THE CHANNEL IN AND LEAVE IT ON SCAN AND IT PICK THEM UP
To enter a known frequency into your scanner:
- Power the scanner ON
- Press the MAN key to stop scanning
- Press MAN repeatedly to select the channel to program
- Enter the desired frequency, including the decimal point
- Press E to enter your data into the scanner's memory
Repeat the process for other frequencies, and press the SCAN button when you're finished programming.
More detailed programming steps are presented in the factory operating manual, which you can download/print, free of charge, here:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Aug 06, 2010 | Uniden BC60XLT Handheld Scanner
RS Pro 2020 Scanner won't come out of scan mode, pad ineffective
If you mean a Bearcat 2020 radio, then that unit is ancient, and I'm amazed that it still works. If you're only monitoring one frequency, you can get a really cheap scanner to do that and replace the 2020.
Aug 01, 2009 | Radio Shack Pro-2018 Scanner
Scanner stopped working
check the windows firewall or antivirus.may be blocking the scanner
Apr 29, 2009 | Office Equipment & Supplies
Scanner making grinding noise
Please open and apply oil on roller rod as some rust have accumulated on it prohibiting it move.
Jan 01, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
Uniden BC60XLT-1 Handheld Scanner Logo
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
