Question about Dell Dimension XPS 400 PC Desktop
I installed 2GB of Crucial memory on my Dell XPS 400 (In slots 3 and 4), but when I rebooted the computer, it booted up but then nothing - blank screen. I tried removing the new memory and again same thing - blank screen... Have I done something really obviously stupid?
    Scholar:
  • 54 Answers
Did you wear a anti-static wrist band when you replaced the memory? Or did you werag gloves?
Please note that you should never touch computer memory with your bare hands, because it can discharge the memory.
Thankfully the chance is very small.
Another thing could be that the memory is not placed right. It has to fit right in the slots.
If you boot up with the old memory do you also get a blank screen? If no, then probably the speed is different. (Please check if it is 533, 677, 800 mhz, or different
Posted on Sep 16, 2010
Maximum Supportable RAM size per slot in Dell N4010
go to crucial memory and download their memory scanner. it will tell you how much memory is installed and what the max is per slot on any computer. hope this helps
Jun 24, 2013 | Dell Inspiron N4010 Notebook
I put the memory stick in my dell but the computer does not upload the device. so I went to control panel in devices and printers and I can see the devices but when i say add to this computer it's
Memory sticks are not devices such as printers and
Dell XPS 400 PC Desktop
Installing RAM on a desktop computer is of moderate difficulty for most non-technical people. Before beginning any memory upgrade, make sure the proper RAM has been purchased. The Dell XPS 400 requires DDR2 RAM (240-pin DIMM).
Preparing the Computer b> The computer must be unplugged before any work can be completed and the proper precautions must be taken, such as wearing an anti-static wristband. Also, replacing the RAM on a Dell machine could void its warranty. To install the new RAM, the case of the computer needs to be opened. Replacing the RAM b> The motherboard has four RAM slots. Each slot takes one stick of RAM (up to 1 GB per stick). The XPS 400 can utilize up to 4 GB of RAM. If adding RAM, put the new RAM in an empty slot. If replacing the RAM, take out the existing one and then put the new RAM into the machine. Important Notes b> While the Dell XPS 400 has four RAM slots, if only two sticks of RAM are to be used, they must be inserted into slots 1 and 3 or slots 2 and 4 for optimal performance. A single stick of RAM should be inserted into slot 1. Always put the largest ram module closest the CPU central processing unit.
Start your computer Wait for Windows to load. Click on "My Computer" and select "Properties" using right-click in the Explorer window. This will open "Systems Properties." Click on the "General" tab. Here you can view the physical memory installed on your computer. The amount indicated is the total RAM installed on your computer. RAM is usually 32 MB, 64 MB or 128 MB in older PC versions. Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
b>If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system. You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Mar 01, 2013 | Dell XPS 400 PC Desktop
Issues with 2gb 32ddr dell memory compatible in dell gx280
Unfortunately, the CPU on these computers may be capable of handling the 2GB memory, the motherboard isn't on either system.
The specs for the Dell GX280 are available here: http://support.dell.com/support/edocs/systems/opgx280/en/ug/specs02.htm . This system takes 400 or 533 MHz DDR2 non-ECC memory and the form-factor determines the maximum memory. In the mini-tower format, you have 4 DIMM slots and can have 4 GB of memory. In the small form factor, it takes 2 GB max.
The Dell E310 specs are available here: http://support.dell.com/support/edocs/systems/dim3100/en/sm/specs0.htm . This system can only support 2 GB (2 x 1 GB) memory.
I wish that I had better news for you.
(who had a similar Pentium 4 computer with the 1 GB limit. Since that system was running a 32-bit system and only actively addressed 3 GB, I didn't try to put 2 GB sticks in any of the 4 memory slots.)
Aug 30, 2012 | Dell Computers & Internet
Where is the memory card slot on the Dell XPS 400?
What kind of memory card are you talking about?
If it's one of those cards from a camera, PDA, etc, it should be on the front of the computer, if you purchased that option.
The normal XPS 400 does not have a memory card reader.
Oct 25, 2010 | Dell XPS 400 PC Desktop
How do you remove and replace dell laptop memory? (d600)
I dont know this particular model, but usually it's underneath the computer, there is one screw to remove and you can take out a door which gives you acess to the memory slots. If it's not there, you will need to remove the top cover to get there. But it's most likely a small door underneath the laptop.
Jun 03, 2009 | Dell Latitude D600 Notebook
CPU Question Dell XPS
have you added new memory
does pc start at all
Jan 16, 2009 | Dell XPS 200 PC Desktop
I have a Dell XPS 400 with Microsoft XP. It recently shut down with a Blue screen stating that a recently installed driver is possibly bad. I was able to restart the CPU after a while and with in a few...
don't reboot instead reinstall the windows may solve this problem.i recommend ur xps laptop use windows vista ultimate because its have great performance i heard.
Jan 15, 2009 | Dell XPS 200 PC Desktop
ACER 9410-4933 LAPTOP ? Won?t boot with 4Gb CRUCIAL RAM
YES THE FREQUENCY OF BOTH RAMS DO NOT MATCH ... THATS BOOTING WITH EACH BUT ONLY ONE BY ONE ... YOU NEED RAMS OF SAME FREQUENCY AND SYSTEM WILL SUPPORT BOTH OF THEM TOGETHER ...
Sep 16, 2008 | Computers & Internet
Dell XPS ONE desktop
if you do this do not tell dell xps support that you did. remove the back cover. you will see two slots for memory. goto your local bestbuy or dell.com and get 2 2gb sticks of the same speed. install memory and replace rear cover.
Sep 15, 2008 | Dell XPS One All-in-One TV Desktop with...
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Dell Dimension XPS 400 PC Desktop Logo
109 people viewed this question
Alun Cox
