Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Half screen picture
When I turn on the tv , I only get a half screen. The bottom part of the screen only appears, top part remains dark
    Genius:
  • Sony Master
  • 1,689 Answers
This is commonly caused by failing capacitors in the vertical deflection amp area and sometimes with the output drive devices.
An experienced TV tech can troubleshoot your set and service it for you.
Jerry G.
Posted on May 25, 2008
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
I have a Sony KDL-40S2000 LCD TV. From the left bottom half of the screen, the picture is dark. I'm not sure if it is the inverter or the bulb, is there an easy method to test? Here is a link to a picture...
I looked at your screen shot of the symptom you are experiencing and it would appear that the very bottom and possibly the next one up CCFL (cold Cathode Florescent Lamp(s)) could be in trouble. If the inverter board(s) was bad the tv would just shut down and blink 4 times but seeing the tv operational but just a dark area near the bottom I would have to say you need to investigate the CCFL problem and replace the affected lamps.
Good Luck!
Rich Lilja
Jan 01, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Model 42mf231d/17 42" plasma
    If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
    Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
    Picture is to big for the TV
    when i turn on my tv just only half screen appear on my TV screen, do u have any i dea to fix this problem.
    Apr 05, 2008 | Philips 20DV6942 20 in. TV/DVD Combo
    Solid Line Across Screen
    Suspect the Light Engine part # 939P977010
    Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
    Screen split with black bar through center, top of picture shows in bottom
    It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
    Jun 14, 2006 | Sanyo DS31520 31" TV
    Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
    145 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
