Question about Sony Ericsson K800i Cellular Phone
Sony ericksson k800i
Cannot see missed calls on the display screen. Checked setting but all seems fine and all call menu tabs show nothing to display in All, Answered, Dialled and Missed.
Hope you can help with this.
  • Anonymous May 22, 2008
    Have 880i phone since Jan 08. No snags until 2 weeks ago &
    now have the same problem as Steve. Missed calls, dialled numbers,
    answered calls all appear empty. Tried everything including Master
    Reset - nothing worked. Thinking of changing phone. Fran
    Brigadier General:
  • 7,752 Answers
Try having the phone reflash.
Posted on Jun 08, 2008
Code reset button
What are you trying to do ? I hope some of this helps.
12 menus appear that are unique to the Sony Ericcson k800i ...
K800i Secret Menu In this post I will write about a few hidden features of the K800i.
These codes should work on most Sony Ericsson models though, try for yourself.
Service Menu
The Service menu can be accessed by pressing the following sequence while in the standby screen:
right, *, left, left, *, left, *
The phone now shows a menu titled 'Service' with 5 menu items:
  • Service info : Here you can view information regarding your handset such as the model number, software versions (firmware as well as other versions, like camera driver version, etc.)
  • Service Settings : Here you can switch USB charging on or off
  • Service Tests : Allows you to test every component of your phone, such as the keypad, microphone, speaker, LED, Display, etc. Any fault can be found out easily with this method.
    In this section, You can also check the Total call time, the number of hours you have called.
  • Text Labels : Better leave this section alone.
  • Discharge Flash : To discharge the camera flash fully.
In addition to the Service Menu, SE's also offer a 'Personalize' menu.
It can be accessed by the sequence
left, *, *, left
But unlike the Service Menu, the Personalize menu is for trained experts only. So it's better not to tinker with these settings. Still, it's cool to know your phone's got all these things under the hood right?
Want to see something cool?
Access the ServiceMenu. Now Navigate to Service Info > Model Info.
While the Model is displayed, press the folowing key sequence :
2, 4, 6, 8
\m/ SE \m/
Stop thieves running up huge mobile bills by locking your Sony Ericsson K800i and protecting it with a PIN To protect your phone from unauthorised use you can set a phone lock to stop others using it.
The default phone lock code on the K800i is 0000, so it is best to change this number to one you can easily remember in case it is lost or stolen. To change your unlock code:
  • From the Menu screen, select Settings (Figure 1).
  • On the General tab, scroll down to Security (Figure 2).
  • Select Locks (Figure 3) and then Phone Protection (Figure 4).
  • Select Change Code (Figure 5).
  • Enter the default code then enter (And re-enter) your new one (Figure 6).
Once you have changed your phone lock, you can then set to either On, Off or Automatic (Figure 7). When it is turned On, you must enter your code when you turn the phone on, Off means you don't need to enter a code. Automatic means that you only enter the phone lock code when a new Sim-card is inserted into it.
Apr 13, 2014 | Sony Ericsson K800i Cell Phones
Damaged LCD, Low battery LED on, wont comunicate with PC.
Replace or Repair the display on the Sony K800i. If your k800i screen is cracked, this guide will help you. If your Sony K800i LCD is dead, then this video will show you how to disassemble and replace it. If your lcd screen on your k800i is smashed, then this post will help you fix it yourself for a very low cost.
Replace LCD Screen on Sony K800i Display
Feb 06, 2010 | Sony Ericsson K800i Cellular Phone
I have a k800i sony ericsson mobile n my problem is that its bluetooth aint workin.
How did you Set up Bluetooth on the Sony Ericsson K800i ?was it set up properly?Sony Ericsson K800i has Bluetooth technology, which can connect to other Bluetooth devices like handsfree headsets, or let you easily swap files like pictures, ringtones, videos or contacts with other people for free. It works by looking for other Bluetooth devices nearby and then connects to them to wirelessly transfer files. this is the steps to seeting up bluetooth on k800i sony ericsson
  • Scroll across to the Connectivity tab and select Bluetooth
  • Scroll down to Phone Name and press select
  • Enter the new name for your K800i
  • Once you’ve done this, you can turn Bluetooth on to make you visible to other devices by following these steps
  • Select Turn On
To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree, Your phone will then look for a handsfree device to connect to. When it’s found it, select the device and enter the passcode if required
Dec 31, 2009 | Sony Ericsson K800i Cellular Phone
How to connect a sonyerricson bluetooth device with my k800i
From the Menu screen, select Settings. Scroll across to the Connectivity tab and select Bluetooth. Select Turn On. To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree. Your phone will then look for a handsfree device to connect to. Press and hold the 'call' (big) button on your bluetooth device. First it will blinks once, keep holding, then it will turn to steady blue. This is the 'pairing' status. When the phone found your device, select the device and enter the passcode (usualy 0000 (4 times zero))if required. The steady blue light on the device should go off and blinks every couple of seconds. Next time you switch on the bluetooth device it will be automaticaly recognized by the phone.
Jun 14, 2009 | Sony Ericsson Bluetooth handset pink...
I work with 2x193W LCD Monitors together. One is working fine, the other is now giving me the "No signal" screen. I have checked connections and pins. Everything seems alright. What am I missing?
Open you video cards control panel and check the display settings. Check to see if it is set to duel view or single display. You can also open your display settings for your computer. Under the settings tab choose which monitor is showing no signal and make sure it has a check mark on the box that says extend my windows desktop onto this monitor.
Jun 08, 2009 | Acer X193W LCD Monitor
When on the home screen the left soft key takes you to your call history. This is divided into tabs, with the first default tab showing all calls and the other tabs showing incoming, outgoing, and missed calls. Each tab shows a chronological list of calls, displaying the phone number dialed. The currently selected item also shows the date and time of the call. The left soft key is assigned to call the currently highlighted item, while the right soft key opens a menu that provides additional functions. Data counters can be found in the phone settings, as well as total call timers and a message counter.
se_w580i_callhistory.jpg During a call the right soft key is assigned to end the call and the left soft key opens a menu with additional options. These options include the ability to turn the speaker phone on and off, add a call for conference calling, place the call on hold, or enable the mute function. The W580i also supports multi-tasking, so you can access other phone functions like your calendar and contacts while on a call. We found the call management feature set on the W580i to be fairly standard, with nothing that stands out, but nothing important missing, either.
Apr 12, 2009 | Sony Ericsson w580i Cellular Phone
Unable to get call log details
I'm a user of Sony Ericsson K800i, unable to get call display, ie., missed call list, dialled call list, number display etc.,
Aug 25, 2008 | Sony Ericsson K800i Cellular Phone
Sony ericsson k810i
my sony ericsson k800i phone has no menu how do i reset menu please help
Jul 15, 2008 | Sony Ericsson K800i Cellular Phone
Registration of Calls
My phone had the same problem on the same day... weird!! done a little investigating and it seems that if you go on the main menu then select calls, then on that screen press the "more" button then select "delete all" - then Jobs a good'un - phone should be working again!!
Sep 03, 2007 | Sony Ericsson K800i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
102 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
