Question about Bosch SHV4803 Dishwasher
My Bosch SHV4803UC Dishwasher latch somehow closed with the door open. The dishwasher thinks its on but the door is open Also, the lights don't come on showing the cycle selection. How do I correct this problem?
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description, "The dishwasher thinks its on but the door is open Also, the lights don\'t come on showing the cycle selection" you likely need a door switch # 165926, also known as a "reed switch by Bosch".
i.e.
This is also based on the model number being SHV4803UC. The part is approximately $20 at most brick & mortar appliance part stores.
I usually purchase them on-line from "searspartsdirect.com" "repairclinic.com" or "appliancepartspros.com" but I suggest shopping around.
**please turn off the power before servicing...safety first**
If you need assistance in replacing the switch let me know I can help you to take it apart etc.
Thanks for choosing FixYa. good luck.
Regards,
Macmarkus :)
Posted on Sep 16, 2010
Dishwasher won't run. Normal light and cancel light flashing cont
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched.The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate. It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Thank you !!
Jun 18, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Bosch dishwasher, SHE43M 30" built-in, door won't latch closed, yet can still start cycle.
check latch on dishwasher side of the unit to make sure it has `nt got loose they make them so you can remove them when the unit is discarded so children can`t get trapped in side
Nov 06, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Opened door on cycle, will not continue cycle after closing door
The most common problem for a dishwasher to not restart after the door being closed is a failed door latch interlock switch. Adjusting / repairing it is not too difficult.
Of course this assumes that the Dishwasher power circuit from the circuit breaker remains powered up.
Post back here if you are looking for more details.
Good Luck!
Apr 16, 2009 | Bosch 24 in. SMU40 Built-in Dishwasher
Bosch Dishwasher SHX46A latch stuck in down possition.
look at the latch via the hole in the door where it closes to the tank? is the latch faced away from the tank? if so, then grab a paper clip and fold it so you can hook it around the latch then just pull outward towards the tank. you might need to hold that paper clip with some pliers. if it happens more than once then you will need to replace that door lock.
Mar 18, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch SHY56A Dishwasher
if the door doesn't shut, the push buttons should not work. that way you are not running your d/w with the door open. check the door latch, as it seems to be malfunctioning. if the d/w still does not work, replace the door latch.
Aug 15, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Detergent latch install for Bosch SHU3307UC dishwasher
you need to remove the front panel of the dishwasher. you need to open the door and remove the 6 torx screws on the inside of the door, close the door and lift up and out to remove front panel. you wiil see the detergent assembly there
Jun 25, 2008 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Bosch SHV4803 Dishwasher Logo
108 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
