Question about RTO PasLode 900420 Impulse Framing Nailer
Everything on my nailgun works but there is 1 problem. The gas is not getting to the spark. any solutions. Thanks.
  • RTO Master
  • 43,501 Answers
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
I have a Hitachi NR90GC2 nailgun and it isn't sparking. I've serviced it and charged the batteries but nothing happens except that the indicator light keeps flashing red!! Please help or advise.
There is a cascade(tripler) that will have problems or may be the isolator in the high volt cable internally to the point where the spark is its a difficult job to do it must be removed try the last aid to use cold cleaning solvent the whole assembly with cable a very little change but after cleaning and blow it dry with a compressor may be a little change
Aug 25, 2015 | Hitachi NR90GC2 Cordless Gas Clipped Head...
Pool heater Hayward H100IDP1 power to gas valve problem
possible gas valve if when quits is there gas pressure if ok make sure not overheating check manual bypass valve
Sep 01, 2012 | Hayward 100kbtu Pool Or Spa Propane Gas...
Gas nail gun not firing
That would be what I would check first. I have seen the large retaining ring break on the Paslodes before. I am guessing it was the large one at the top of the cylinder? If all of the wires are intact then it may be a circuit board if it is like the Paslode framing tools. I have never worked on a Powers brand but the Paslode has a "board" that contains two micro-switches, one that tells the fan to start and one that sends the signal to the spark unit.
Feb 25, 2012 | Tools & Hardware - Others
My Husqvarna 455 starts great and sounds great without pressure but when you put the saw under pressure of cutting it bogs down and runs up and down. I am not sure the problem. I have changed spark plug,...
If you haven't done so already I would run some spray carb cleaner through it. If the idle speed is okay then I would adjust high and low screws going very slowly about 1/16 of a turn at a time and run engine up and down after each adjustment. I would remove the muffler and clean the spark arresstor screen to get all the carbon deposits out of it.Carb. cleaner and a medium stiff wire brush work well for this. I would also check the vent in the gas cap to make sure it is open. I also use a product called sea foam in all my engines.For my chain saws I mix 5-6 ounces with 2 1/4 gallon of gas.It really does a good job of keeping everything internally clean. Hope this helps you. Thanks.
Jul 28, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
My whirlpool gas cooktop on sparks on left front burner. Model scs3014gq1
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 01, 2010 | Whirlpool SCS3014 Gas Cooktop
Engine is getting gas and cranks over but want start. any solution will help thanks
Have u checked to see if your getting spark? Quick way to do so is remove the spark plug and hold it by the sparkpkug boot against the cylinderhead and crank the engine. You should be getting a spark if everything is functioning properly.
Jan 03, 2010 | 1996 Suzuki LS 650 Savage
Nailgun does not work, air is
Check to see if a nail is jambed part way in the chamber outlet, make sure to take air hose off before checking. You also may want to add some air gun oil to the inlet if you havnt done it in a while
Oct 29, 2009 | Porter Cable FR350A Factory Reconditioned...
Dewalt nailgun wont punch nails
dewalt nailgun jamming "constantly"
Oct 13, 2009 | Dewalt DC618KA Angled Nailer Kit
Fouling plugs
Get a new NGK spark plug one heat range hotter than stock. Be sure the fuel mix is 32/1 using two stroke engine oil ( not motor oil ). A 32/1 mixture equals 4 ounces oil to 1 gallon of gas. Remove the cylinder head and de-carbon the top of the piston and head.
Please rate this solution. Thanks!
Apr 07, 2009 | 2003 kawasaki KX 125
Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
Mar 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
RTO PasLode 900420 Impulse Framing Nailer  Logo
109 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
