Question about AOC 917Sw 19" LCD Monitor
Monitor has gone blank. will come on for 2-3 seconds after restart then goes blank again. Is powered up, blue light, not on standby orange light. Bough in April 09 perfect up until 2 days ago! Current driver is up to date.
  • 11,361 Answers
Inspect the inside first for bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 16, 2010
HP Touchsmart IQ526- Black Screen and Amber LED please help! No display. Is this a hard drive issue?
Also had this issue on the Touchsmart IQ526. Removed the CMOS battery, waited some minutes, then powered on. The power button remained blue and had video again. Reinserted the CMOS battery and put the unit back together. Note - the battery was on the mainboard.
Mar 24, 2012 | HP TOUCHSMART IQ526 PC PC Desktop
Monitor is switching off immediately after system is switched on. Again when monitor is switched on, images appear for about 3 seconds and again monitor switches off.pl give the solution.
You need to determine if you is turning off or going into standby mode. When your monitor shuts off, the power light will turn orange if it is in standby or the light will turn completely off if the monitor turns off. If your monitor goes to standby, that means that your monitor is losing signal which indicates a problem with your PC. #1 Make sure cable is firmly secured and both screws are tight #2 Check your video card make sure that it is firmly in its slot. Take it out and put it back in. *as long as your computer is open give it a good cleaning with compressed air* If those things check out it is possible that your video card has failed and needs to be replaced.
If your monitor is powering off #1Check plugins- try something else (i.e. lamp) in the outlet #2 Try your PC's power cord in your monitor
Oct 21, 2010 | ViewSonic Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen goes bank after 2 seconds even if powder light is on
i just finished repairing a 20 inch acer monitor that had the same issue.... you have to take it apart and examine the power supply side of the monitor. there are capacitors that go bad on that board. you can tell be feeling the tops of them... the feel rounded. replace the capacitors and put it back together and it will work fine
Apr 16, 2009 | Computers & Internet
Blank monitor
Luckily I'm not in it for the money so here's your answer. (Sorry drumbanger.)
When it goes black, look at your power button. Is it still green? If so, the backlight display is bad. If the power light has turned orange, you're most likely looking at a power/inverter problem. Sadly, if you don't have another monitor that you can swap parts out with, you're looking at a new monitor. But with the economy on the downslide, replacements keep getting cheaper! Research online and you'll find some fantastic deals! Rate me if you find this helpful.
Feb 14, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
X191w blank screen after 2 seconds
Just got off the phone with Acer Suppport. This was after I sent an email to them, that suggested that I call. 8-/ annoying. So the guy on the phone says there is one thing that we can do before sending it in. Unplug it completely for the wall and computer. Hold the on/off button in for 30 secs. reconnect power and the computer. It worked for me
Oct 07, 2008 | Acer X191WSD Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Hp1903 blank screen
power shortage maybe...try to plug your monitor on the other power supply,,be sure that your monitor is compatible on the voltage it required..
Aug 04, 2008 | HP vs19 (Silver) 19" LCD Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Medion AE19E1 (second hand)
sir,,i think theres something wrong with the power supply,,,kindly checkthe power supply of it,,,thanks and hope to help you thnkss??
Jan 28, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
AOC 917Sw 19" LCD Monitor Logo
120 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
