FixYa.com
Tags:
Copiers
Generic problem for all Sharp Copiers
Sharp copier model no. DM1505, will not copy
posted by cosmome on May 17, 2008
flashes h and 4 alternatly will not respond to any controls. what can i do to fix it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 19, 2008
FixYa! (100)
hemantraj
Rank:Master Master
Rating: 70%, 85 votes
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Rating Locked! (?) cosmome has rated this solution as FixYa!
Solution #2
posted on Jul 22, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks! It really works.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier Sharp AR-C160 Color Copier Sharp AR-BC260 Color Copier Sharp AL-1641CS Color Copier Sharp AL 1215 Black and White Copier Sharp AR-168S Grayscale Copier Sharp AR-507 Grayscale Copier
Can you Help with these Copiers problems?
Toshiba e-Studio 232 Black and White Copier
Toshiba e-Studio 25 and Windows...
I have a Toshiba e-Studio 25... Answer This...
Toshiba e-Studio163 Grayscale Copier
COPY IS NOT GOOD....
i have a e-studio 163 copy and... Answer This...
Canon imageRUNNER 5020i Copier
Need User Manual
Purchased refurbished Canon... Answer This...
Toshiba e-Studio65 Copier
low toner
I replaced the toner but it... Answer This...
Canon ImageRUNNER 330s Grayscale Copier
Adding Staples Image Runner...
We have an Image Runner 330S... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
