Question about Jura Capresso C3000 Espresso & Coffee Maker
My capresso 3000 coffee maker leaks water out of the rear of the machine. Is it possible for me to repair the leak myself?
SOURCE: Bunn Coffee Maker Leaks out the bottom
Contact Bunn and they will send you a free repair kit with good illustrated instructions.
Posted on Aug 17, 2008
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
Posted on Dec 30, 2007
SOURCE: my bunn coffee maker leaks
Experiencing same problem. Appears there may be a recall depending on your model and production date. I suspect it is the small seal washer where top fill tube attaches to the top of the tank. Water leaking here would flow done inside the round steel body and leak out bottom.
Posted on Aug 18, 2008
SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Posted on Sep 15, 2008
  • 5 Answers
SOURCE: Coffee Maker leaks
its from around the rubber seal the seal needs to be replaced
Posted on Dec 14, 2008
My machine is leaking clear water. I ordered a new water tank. However, that is not the solution. It is still leaking. Wondering if there are any repair shops near Wilmington, NC
Check the membrain regulator for leaks. Those end up leaking over time as they get older. They look like this:
http://i.ebayimg.com/00/s/MTYwMFgxNTk5/z/XMAAAOSwl8NVdZz4/$_35.JPG
and are located on the outlet side of the water pump. They can be bought for about $50-60 and just screw on to the outlet side of the pump.
Sep 28, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
Why does my coffee maker Capresso Team GS leak water?
Hello, what I have found is the most common cause of water leaking out of the bottom of the capresso team coffee maker is a leaking silicone hose that runs to the boiler (See the photo below with the split in the hose). The replacement silicone hose needs to be safe for beverage dispensing, food & dairy processing, taste and odor-free, with a temperature range of -75? to 350? F. All you need is a sharp pick, a phillips screwdriver, and a pair of needle nose pliers. Remove the four rubber pads on the bottom using the pick. Use the screwdriver to remove the six screws holding the bottom plate on. Remove and replace "BOTH" hoses using the needlenose pliers to pinch the hose clamps. Better to play it safe while you have it apart. If one is bad the other is likely not far behind. I hope this helps. acccadfd-0d5d-4c31-b1b9-a56192db9bc2.jpg
May 09, 2014 | Jura Capresso CoffeeTEAM GS 46405
Leaking steam valve
Jura are a top brand and offer service and repair on their machines. Ask your local Jura dealer for a repair estimate.
Dec 20, 2013 | Jura Capresso Impressa E9 Espresso Machine...
Leaks water
There are many possible points that the leak can be.
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Jun 10, 2010 | Jura Capresso CoffeeTEC 471 Coffee Maker
Impressa E8 water leak
Did anyone find an answer to this - sadly we have the same issue.
Feb 07, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
It leaks clear water underneath on right side
Hi, wondering if you found the solution, my S9 is doing the same thing. Thanks
Feb 04, 2010 | Jura Capresso C1500 Espresso & Coffee...
E8 leak
If leaking water from right front when brewing, cleaning or steam then the possible problem is the feed tube from the pressure pump this is mounted with a small o-ring and either the pipe is fractured or the o-ring has perished.
Feb 05, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capresso C3000 Espresso & Coffee Maker Logo
123 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
