Question about Hotpoint FFM90 Bottom Freezer Refrigerator
Freezer is getting icy!
My freezer has just started freezing up can you please help as to what could be wrong?? Also every night the buzzer goes off and temperature has changed when no one has been in there for ages What could this be?
Dave T
  • 3 Answers
SOURCE: freezer of refigerator (coils keeps freezing over)
I had the same problem, i took mine outside and spayed degreeser on the coils and power washed it off. the coils get built up with dust. make sure you dont have it pluged in when power washing it. lol. good luck
Posted on Jul 28, 2007
Cerfer39
  • 709 Answers
SOURCE: GE Frigerator has intermittant Freezing
It sounds like the defrost heater is burned out. Remove the inside back cover in the freezer to see if the coils are frozen up. If so, more than likely your defrost heater has bit the dust. It is located at the bottom of the inside coil of the freezer.
Also, you could be have a clogged condensor coil. It is located on the out side back of the Fridge. You need to remove the panel from the lower part of the fridge and do a thorugh cleaning.
Posted on Nov 03, 2007
  • 14 Answers
SOURCE: Bosch Fridge Freezer Classixx
This button is the winter/summer setting.
If you switch it on so as the red mark shows this is set for the summer setting.
What it does is allows the interior light to come on very dimly when you shut the door.
The fridge then thinks it is too warm and starts to cool down more, designed for when the ambient temperature is high.
Hope this helps
Deep diver
Posted on Jan 17, 2008
SOURCE: hotpoint ff175b fridge freezer
I had the same problem. Hotpoint told me it was the electronic card, and I waited 3 weeks for them to get one in stock. Just been fitted and made no difference, though the Hotpoint man told me it was fixed. I have just spent half an hour "shaking and whaking" various bits at the back of the fridge freezer and the compressor has finally kicked into life.
Concentrate your shaking and whacking on the black square thing to the left of the compressor.
Going to quit my job and become a freezer repair man.
Posted on Jun 17, 2008
  • 260 Answers
SOURCE: Freezer stopped freezing up?
check the compressor to see if it works. You should hear a sound that sounds like a low hum.
Is the compressor fan on at the bottom rear of frig?
Posted on Apr 09, 2009
Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Mar 13, 2013 | Kenmore Freezers
GE chest type freezer buzzer going off
If you have a fast freeze button try that and see if the alarm goes off within a few hours. It bypasses the thermostat switch. Check condenser clean etc but be prepared for compressor failure
May 19, 2012 | GE Freezers
It does not freeze the top it mild cold not icy. the bottom does not even keep milk cold it goes soure.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 23, 2011 | Heating & Cooling
Warning buzzer keeps coming on ,ice maker dose not work , top of freezer no freezing properly
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Dec 30, 2010 | Refrigerators
There is icy in radiator aluminium, fun is working olso meat it doesn' t get freeze icy maker is no working. what could be the problen?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | Frigidaire FRS26R4A Side by Side...
Making alarming buzzing sound. Still freezing fine
putting unfrozen food in a freezer can raise the temp to cause it to go off allow 24 hours for it to stop if it dont replace the buzzer
May 23, 2010 | Whirlpool Upright Freezer EV161NZRQ
Alarm goes off and freezer not cold
The light indicates the need for a new battery (9V)
Jul 21, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
New 3.6 Danby freezer not freezing
maybe you should go with a different brand???
Feb 04, 2009 | Danby 3.6 cu. ft. / 102 liter Chest...
Ice cream is soupy & when I freeze it it becomes icy
Freeze the bowl for at least 24 hrs, rather than the 12 hrs the manual suggests - it will make all the difference in the world. For really thick ice cream, freeze the bowl for a day, and then put the ingredients in the freezer until the outer rim becomes frozen. Very delicious!
-Tha Mp3 Doctor
Dec 10, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Mar 02, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Open Questions:
See all Hotpoint FFM90 Bottom Freezer Refrigerator Questions
Hotpoint FFM90 Bottom Freezer Refrigerator Logo
181 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
