Question about Xplore Technologies iX104C3DV XP-TabletEdition Xplore Allvue Technolodgy Tablet PC
Targus Card reader--computer recognize new hardware--but that is far as i can go. have xp computer-- it don't tell me new device detected--it always selects scanner
    Brigadier General:
  • 3,917 Answers
Please check this links:-
http://support.microsoft.com/kb/314634
http://ask-leo.com/why_wont_my_system_recognize_my_usb_device.html
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Posted on Sep 16, 2010
Will not recognize square card reader.
Computers can be ornary creatures. See if the reader is recognized by another machine. If so then your machine is simply not compatible with the reader and will not function. It happens.
Jun 22, 2015 | Tablets & eReaders
Attempting to use my Square reader
Try turning off your device, then back on. If you still have trouble with your square, delete the app from your device & reinstall it. It should work then. If not contact square reader customer service.
Mar 06, 2015 | Tablets & eReaders
How is Micro SD card formatted on D2 Tablet?
I believe more than one manufacturer uses the model number D2 for their device, hence I can not even begin to provide a proper answer.
Suggestions: if you have a personal compute and access to a card reader connect the card to your computer via the reader, find the card on your computers file manager (windows explorer on a windows PC) and, if using windows, right click on the icon for the card, then select properties; that should tell you what the for mat is, Fat32 or NTFS.
You can also do a google search for a support forum for your device and ask there
Have a Magical Day
K
Jul 26, 2014 | D2 Racing Pad 7 Inch Tablet With 4gb...
When i plug in my velocity cruz reader into the usb port it tells me that the USB Device Not Recognized?????
Chances are the reader is defective. Try to plug it into another computer to confirm this. If it works try another USB device to confirm that the port is working.
Jul 21, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
My lap top Acer 5000 windows xp 32 bit is not recognizing the new device -- My computer is stating, incert disc -- Please help -- I want to transfer photos to my tablet --
That is because XP was designed 10 years before you got your Tablet and there is no driver for it so as far as XP is concerned, it does not exist.
Sorry.
Feb 15, 2011 | Coby Kyros 716829701508 Tablet PC
Hi, 1. How to transfer/copy bootable XP files onto SD card and then boot up Toshiba Portege M205 from the SD card? 2. Is it possible to made an image of my Windows XP CD on SD card? Regards Tad
Requirements
  • PC running Windows XP/2000 with a CD/DVD burner.
  • USB Flashdrive (Or some way to transfer files to the 3epc once Windows is installed)
  • SD Card, a fast SDHC is recommended of at least 2GB.
  • XP3eSD Utility
  • Hitachi Microdrive Filter Drivers
  • Partedmagic (or another bootable CD with disk cloning software)
  • Windows XP CD (SP2 Only Tested, may work with others)
  • Asus Eee PC (Of course!!)
Instructions:
  1. Copy all files from your XP Install CD to a folder on your Hard Drive
  2. Download the XP3eSD utility and run it to create a new install CD capable of installing Windows to boot off the SD card reader
  3. Boot your 3epc from the CD made in step 2
  4. Install Windows onto a FAT partition, deleting all the existing partitions
  5. When windows boots for the first time turn off the swap file, system restore, and the screensaver.
  6. Then stick your USB thumb drive into the EEE with the Hitachi Microdrive Filter.
  7. Next copy the files from your thumb drive to the desktop and then properly remove the thumb drive.
  8. Unzip the microdrive files to a folder on the desktop. And Insert your SDHC Card into the EEE.
  9. You need to then Hit Start go to run, and type regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USBSTOR\
    Inside that you should find a directory called something like Disk&Ven_USB2.0&Prod_CardReader_SD0&Rev_0100. Open it. Inside that you should find another directory wich is just a bunch of numbers. Open it. In the right pane you should see a key called "Hardware ID" Right click on it, and select modify. It should list about 7 lines of text. Copy ONLY the first line to the clipboard. Hit cancel, close regedit.
  10. Open cfadisk.inf in the directory you unzipped the microdrive filter to. Edit the section called [cfadisk_device] so that rather than containing 11 lines, just have one line. The line begins with: %MicroDrive_devdesc% = cfadisk_install,
    After the comma, hit ctrl V to paste what you coppied from the registry into the file then save the file.
  11. Go to Device manager. Under disk drives, you should see SiliconMotion and USB2.0 Card Reader. Right click on the card reader and click update driver. Direct the driver updater window to the Hitachi driver you just edited. It won't detect the driver automatically, you have to specifty that your supplying the disk for the hardware and force it to use the driver.
  12. Reboot using the Partedmagic CD or USB Flashdrive, Download it here
  13. Create a FAT32 partition on the SD card, same size as the one on the SSD in your 3epc
  14. Use 'fdisk -l' to find out the partition names of your SSD and SD.
  15. Type this command into a prompt: 'dd if=/dev/sda1 of=/dev/sdb1' When it finishes (it will take some time) type this command: 'dd if=/dev/sda of=/dev/sdb bs=512 count=1' (Note: If fdisk reported your SSD and SD as different than sda and sdb respectively, you must change that in the dd commands, if unsure ask in the support forums)
  16. When it finishes the task is complete, reboot and select to boot from the card reader
  17. Re-image the SSD of your 3epc with your restore DVD or USB.
Jan 27, 2011 | Toshiba Portege M205-S810 Tablet PC
Just bought a cruz reader r101....usb says device not recognized. I am on XP sp3
Before you can communicate with your computer you must run CruzSync from the desktop. There are some driver files that must be sent from cruz to point the way to the reader. After you do this it should connect every time. Some time you will have to pull the USB out and put it back end, especially if the reader or the computer has just woke up from a sleep or hibernation mode. ZumoDrive is the account you must set up when you click or press on CruzSync to make all of this happen. Hope this helps
Jan 02, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
How do i load pictures from a sd card into computer
determine if your computer has a memory card slot for sd cards..
if memory card slot is not available use a "card reader" you can get that from walmart and on other stores
once memory card is connected.. it will appear on your
computer as a removable disk or device.. you can check that on "my computer" window for XP or "computer" window for vista..
you can explore the content of the memory card and get your files.. good luck!!
Sep 24, 2009 | Gateway CX200S Tablet PC
Red bridge multi in one memory card reader not recognised
I insert my Red bridge multi in one memory card reader and a 2gb M2 card(with data) in the right slot yet I receive a please insert disc?? when I click the removeable (H)of Red bridge(which is detected by my pc)
May 29, 2009 | Tablets & eReaders
Xplore Technologies iX104C3DV XP-TabletEdition Xplore Allvue Technolodgy Tablet PC  Logo
98 people viewed this question
Top Xplore Technologies Tablets & eReaders Experts
Hardeepak Bhambh
Hardeepak Bhambh
Alun Cox
john1959ny
john1959ny
Are you a Xplore Technologies Tablet and eReader Expert? Answer questions, earn points and help others
