Question about Canon ZR900 Mini DV Camcorder
External microphone won't work - Canon ZR900 Mini DV Camcorder
Is acer aspire aspire 4530 has built-in microphone?
Typically YES, this laptop also has a PLUG for a EXTERNAL microphone. Any external microphone will work with the laptop.
Nov 06, 2011 | Acer Aspire 4530-5889 Notebook PC
Internal microphone not working on Gateway M-6843
First check the settings under Sound Settings of the Realtek HD sound Manager. If everything looks ok and it works with external microphone, then the problem could be Hardware problem which won't be fixed unless the motherboard is replaced.
In the meantime, I would also suggest you to uninstall and re-install the sound driver. By the way, what's the operating system installed on your laptop?.. Hope this helps.
Let me know if you need further help..
Good Luck.
Thanks for using FixYa.
Sep 06, 2011 | Gateway M-6843 Notebook
Hello there, my mic won't work.
The external microphone input is most likely dirty and causing the internal microphone connection to be disconnected. The mic socket is at the front edge next to the headphone socket. try cleanig with a vacuum cleaner first to clear any dust and fluff. Then use a cotton bud and cleanig fluid e.g. WD40 or contact cleaner, or CD cleaning fluid.
May 26, 2011 | Nintendo DS Lite Console
Does the acer aspire 5532 have a sound card or built in microphone?
I believe it has both, strictly speaking it won't be a dedicated sound card as such but the capability will be integrated onto the motherboard. According to Acer Support the 5532 has High-definition audio support, Two built-in stereo speakers and is MS-Sound compatible. The peripheral subsystem has a Headphone/speaker/line-out jack and a Microphone-in jack should you want to add an external microphone for better quality recording.
Apr 14, 2011 | Computers & Internet
My acer aspire 4720z mic is not working but the output audio is ok
Try plugging in an external microphone. If it works, then your internal microphone has failed. If the external microphone also doesn't work, then try reloading the Realtek Audio Driver. There is also the possibility if you have previously used an external microphone, that the jack's connections have become unreliable such that the system thinks that an external microphone is still connected after it has been unplugged. With this situation, plugging an external microphone back in will obviously work.
Mar 18, 2011 | Acer Aspire 4720 Notebook
External Microphone on Compaq C700 series don't work.
just check in BIOS whether the setting for the external microphone is on or not.
Apr 10, 2009 | HP Compaq Presario C700T
Cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 16, 2009 | Compaq PC Microphone (Black or Beige)...
Microphone is not working
i have compaq Presario c700 laptop
but my external microphone is not working & also inbuilt microphone is not working.
Feb 02, 2009 | Compaq Presario 700 470024-192 Notebook
Microphone problem
Hi!
integrated microphone really wont work on xp. it's either there's njo choice for us or they are still working on it (which i don't believe). Sorry but the system was designed for Windows Vista that's why, there's no driver designated for XP.
Thanks,
Karlox™ :)
Jun 05, 2008 | Compaq Presario 700 470024-192 Notebook
Jack for the external microphone
There is an error in the MobilePro 900 manual (Pages 2-2 and 2-3). The jack on the front of the MobilePro 900 is a stereo headphone jack only. The MobilePro 900 has a built in microphone. There is no jack for attaching an external microphone.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Canon ZR900 Mini DV Camcorder Logo
49 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
