Question about White Sewing 1300DE Sewing Machine
Can I use the oil for shredders in my singer merritt 1872???
  • Mary Dunn Sep 16, 2010
    Do you mean feed dogs? There is no such thing as a shredder on a sewing machine. If, you mean feed dogs, I wouldn't if you don't want to stain your material
Where would I oil a singer Merritt 4530 model machine
Singer has the manual for the Merritt 4530 on their manuals site: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/437_5_6_8_10_slide.pdf . See page 44 for the picture of the points were you should apply sewing machine oil. You'll need to oil 8 points under the face plate on the left side of the machine. Most are places on the needle bar shaft. There are a few connected to the thread take up lever. If you move the hand wheel, you will see most of the points that need lubrication.
I hope this helps.
(In this case, the picture is much clearer than any verbal description I could give.)
Sep 21, 2016 | Singer Sewing Machines
Is there free manual for singer merritt 2502C
There sure is! Just go to the Singer sewing machine site, and there's a page where you can type in your model and click the button, and your machine is right there for free download.
Jun 28, 2014 | Singer Sewing Machines
What size needle for Merritt singer 3014
I could not find a Singer Merritt 3014 nor a Singer 8280. Do you have the serial number and/or model number? You can always try this site:
http://www.singerco.com/products
Jun 11, 2014 | Singer 8280 Mechanical Sewing Machine
How do I oil the gears by the bobbin holder ona Merritt Singer 4530?
here is a link for a free manual
if the information isn't in the manual, then you'll have to contact
singer customer service and ask them if the machine can be oiled
or if it's self oiling
Mar 21, 2013 | Sewing Machines
How do you thread a singer merritt 1872?
Wow, one of the few Singer machines that doesn't have a free download manual. Hmmm..... Ok looked up a photo of your machine. It's pretty easy.
1. raise your presser foot.
2. Put thread on spool pin.
3. draw thread over to and under from behind of the pre-tension disc at top
4. Draw thread down from the right and under the tension dial to seat the thread into the tension discs and flex that spring a little.
5. Through the take up lever.
6. Down through the thread guide.
7. Down through the needle bar thread guide.
8. Through the needle.
Hope that helps.
Aug 20, 2012 | Singer Sewing Machines
Need manual for Singer Merritt 1872 machine
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 1872 ) & click search
Apr 26, 2012 | Sewing Machines
NEED MANUAL FOR A SINGER MERRITT 1872
Hello! I had the same problem! I just found a piece of it about 5 minutes ago haha this tab was open and I was going to close it!
unfortunately this is just the threading diagram(still very important though)! c: I hope this helps the both of us!
Jan 25, 2012 | Sewing Machines
Need a manual for Singer Merritt 9612. to download if possible.
Free downloadable manual for Singer Merritt models 9610, 9612, 9614: http://www.singerco.com/uploads/download/663_9610-9612-9614.pdf
Mar 30, 2009 | Singer 20U73
Singer Merritt 8834-My bobbin Wheel is Locked :'(
pull it towards you. if this does not work take off the rubber but usually you put finger underneath and pull. or catch on side of bobbin winder. hope this helps try oiling it as well. the spring or hing bit.
Mar 26, 2009 | Singer 7462 Mechanical Sewing Machine
White Sewing 1300DE Sewing Machine Logo
111 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
