Question about Acer Aspire 5520-5908 Notebook
My cd/dvd drive does not show up in my computer or device manager, I also cannot use is now that it is not showing. How can I correct this problem?
  • 244 Answers
SOURCE: DVD-RW optical drive
is your dvd detected in bios ?
if yes, it's windows issue.
follow the step by step from this link:
http://support.microsoft.com/kb/314060
Posted on Feb 29, 2008
  • 37 Answers
SOURCE: my cd-rom drive cant be found code 19
try this, go to reg edit and then go here HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} then delete upper and lower filters then reboot the computer, hope this helps
Posted on Oct 11, 2008
leecom72
  • 4806 Answers
SOURCE: acer aspire can't find the dvd to play cd's
again this is a classic vista problem, i have worked with vista machines for a while now and still i can't find the reason vista does this. I did find a soloution that worked on a few machines but not on all!!
i put the computer to sleep and woke it again using the on/off button and it came back.
try this !!!
good luck
Posted on Nov 17, 2008
  • 10 Answers
SOURCE: CANNOT FIND CD/DVD DRIVE ON ACER ASPIRE 5100
Is the hardware listed in the BIOS? When the computer first starts up hit a key to get in the BIOS (Esc, F2 or F10 are most likely). If it's not listed in the BIOS then it's likely a hardware problem. Try checking the connections to make sure it's plugged in and getting power.
If it is listed in the BIOS, it's likely a problem within Windows. Check Acer's website for known issues with the cd-rom.
Posted on Nov 25, 2008
colt_baldwin
  • 103 Answers
In the device manager, select the DVD ROM and UNINSTALL / REMOVE the device.  Restart Windows . . . did this work?  If not, boot into your CMOS and see if the drive is being detected by the motherboard... if yes, look further and make sure the settings for the drive are correct. Make sure that all IDE interfaces are enabled in the CMOS settings (both)
Posted on Dec 25, 2008
Acer aspire 5740 DVD not recognized
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Oct 25, 2012 | Computers & Internet
Hp AV6700 does not see CD/DVD
Disc player fix!
Oct 16, 2012 | Computers & Internet
My dvd rom is not showing in My Computer
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Aug 18, 2012 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Windows: USB Dongle shows up in Device Manager as Disk Drives: KVM vmDisk USB Device, and DVD/CD-ROM Drives: KVM vmDisk USB Device. Steals drive letters I need. How to get around this? have uninstalled...
Hi Bruce:
Sorry to hear that you are having problems. If you still want to use the device, you can assign drive letters to you other devices that do not disrupt the use of you KVM switch. Using device manager, you can change drive letters on all drives except your hard drive, usually drive 0.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
As for uninstalling the KVM device, if you want to completely remove all files from your computer, do a search (off the start menu) and search for *KVM vmDisk USB Device".
The delete all the files that are found in the search.
Let me know if I can assist you further or you need any clarification on my instructions.
Jan 12, 2011 | Avocent DSR2035 (DSR2035001) 32-port KVM...
Optiarc dvd rw driver shows code 19 error .i have tryed to reinstall ,but no use.
The below step will surely resolve the issue..
CD/DVD drive in device manager and the CD/DVD properties in device manager shows error code 10 , 19 , 31 , 32 , 39 or 41, please use the following steps:
This issue occurs due to an incorrect registry entry, which might be created due to installation of an incompatible CD/DVD burning program. We will remove the registry entry and re-install the CD/DVD drive and the issue will be fixed.
1. Click on Start and type regedit in the search box and hit enter. It will open Registry Editor window.
2. It will open registry editor.
3. Click on File and Export, it will open a new window.
4. Select Desktop from left pane in the new window and put file name as regbackup and click on Save.
5. It will create a back up of the registry on desktop.
In case something goes wrong during modifying registry, this registry backup can be used to restore to original registry.
6. Now in registry editor click on triangle symbol next to the following items in the left pane:
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
7. Locate 4D36E965-E325-11CE-BFC1-08002BE10318 below class and click on it. Make sure you have selected the correct entry as all the entries looks almost similar.
8. Look at right pane and check if you see UpperFilter and LowerFilters entries.
9. Please right click on UpperFilter and LowerFilters and select delete.
10. make sure there are no other UpperFilter and LowerFilters entry in that window.
11. Close registry editor.
12. Now please click on Start and type device manager in the search box and hit enter.
13. It will open Device manager window.
14. Click on + sign near CD/DVD entry and it will show the name of the CD/DVD drive with a yellow mark near it.
15. Right click on it and select uninstall.
16. It will remove the CD/DVD entry from device manager.
17. In Device manager, click on Action > Scan for hardware changes to re-install CD/DVD drive.
18. Now you should see the CD/DVD drive entry.
19. Do you see any yellow mark near it now?
20. Please click on Start > Computer and check if CD/DVD drive is listed.
21. Please insert a CD or DVD and check if the computer reads it.
May 08, 2010 | Computers & Internet
My computer isn't seeing the D Drive at all how can I resolve this
go to control panel, system, hardware manager. .and see if it's showing up there..if not,try scan for hardware changes..of course, if you provide the operating system and computer type that will help too.
Dec 06, 2009 | Samsung DELL CD-RW/DVD DRIVE SM-332 BLACK...
D: (NEC DVD) drive no longer visible
If the device is showing then try this.
Uninstall the driver and delete the device from the Device Manager.
Shut the computer down completely.
Then re-start the computer to see if the operating system detects the drive and re-installs the driver correctly.
Jan 27, 2009 | NEC (2660000400) DVD Drive
Acer aspire can't find the dvd to play cd's
Dec 13, 2008 | Acer Aspire 5315 Notebook
Cd and dvd do not work
  1. what OS? XP? if yes, is SP3 installed? XP has big troubles with dc/dvd or BRD drives. so, say what OS first.
  2. driver must match OS, so....
  3. what media are you attempting to read, CD, DVD, Blueray
  4. is said media, (real) or is it record-able , like CD-r or DVD-R
  5. we have idea what you have there , only a620 old.
May 06, 2017 | HP (176135-630) (176135630) Internal 48x...
Acer Aspire 5520-5908 Notebook Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
